    pabloabbs's Avatar
    pabloabbs Guest
    Mitsubishi controls
    can anyone shed some light on fitting interfaces to mitsi mr slims. I have a wallmount with wireless remote want to fit run/fault indication what should I use and how is it fitted
    Valrico, Florida
    509
    Re: Mitsubishi controls
    I don't know the answer to your question, but welcome to RE, I'm sure someone here knows the answer to your question.
    Mar 2007
    Warwickshire UK
    723
    Depends which model, but the old 5 wire addaptor should still good for current R410a models.
    UK part No PAC-SA88HA-EP cost about £10.00
    It plugs into the indoor unit circuit board & can be wired up for remote on/off control & remote run/fault indication. You might need a 12v d/c relay & a 12v d/c power supply depending on exactly what you are trying to do.
    If the site has City Multi systems & G50 or MJ103 or Mj310e central control then you could push out the boat & fit M-net interface & control from the central controller. Much better but cost for the interface is about £110.00.
    Aug 2007
    Russia
    139
    22
    Quote Originally Posted by Thermatech View Post
    I guess this leaflet will be useful
    http://www.mitsubishi-electric-airco...leaflet_GB.pdf
  1. Mitsubishi vrv
    By dakesojo in forum Air Conditioning
    Last Post: 22-09-2009, 01:04 PM
  2. Mitsubishi Light Truck Refrigeration
    By Mastercool in forum Transport
    Last Post: 23-11-2007, 06:15 AM
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. Mitsubishi SRK
    By daddymac in forum Air Conditioning
    Last Post: 26-04-2007, 08:47 AM
  5. Mitsubishi problem
    By marc5180 in forum Trouble Shooting
    Last Post: 17-01-2007, 10:06 PM
