    Mar 2006
    66
    92
    CO2 chrarging in low ambient
    Hi anyone one had problems with charging with CO2 when it’s bloody cold?
    if you cant't fix it don't
    Jul 2010
    manchester
    212
    Re: CO2 chrarging in low ambient
    what type of system is it ?
    your only as good as your last job
    Mar 2006
    66
    92
    Tesco star packs, Advansor, Just a general enquire, if anyone has come across this, you can overcome this by lowering the suction set point, to get below the standing pressure of the bottle. or put the bottle in your van and drive around with the heater on for a hour
    Nov 2009
    Western PA
    49
    I suppose that it's no different than charging any other refrigerant when it is cold.
    You must create a pressure difference between the container and the system to create flow.
    Lower the system pressure or heat the container to raise that pressure.
    Use a bottle warmer.
    Jul 2010
    manchester
    212
    Tesco star pack lower the suction target pressure via the 255 but be careful because as your putting the bottle in and your pressure rises in the gas cooler it can cause the discharge PRV to blow off because the fans can be a bit slow on reacting to the pressure. On the advansor packs lower the HPR receiver pressure via parameter n71 on the 356 controller to around 32 bar 31 minimum and that would drag the bottle in no problem.
    You can reduce the HPR pressure by the 255 aswell but i just do it via the 356 i find it quicker.
    Mar 2006
    66
    92
    Thanks cold. Man for that tip, I haven't had to recharge an advanser pack yet not like star packs I am always adding CO2 to them.
    Jul 2010
    manchester
    212
    Most leaks i have found have been at the transducers, or schraider valves. dont think many tescos have the advansor packs mainly star packs. I think they have now been around and got rid of the vulcan fittings on all stores aswell and braized the pipework which should of been done in the first place in my opinion.
    I find the advansor packs alot better than the star packs the SCM packs are ok aswell but the layout is poor.
    On charging the advansor packs just remember when charging get the correct pressure in the charging line with vapour as you would with the star packs but ensure the charging port is fully open before opening the bottle because you will blow the PRV on the charging line.
    Not sure about the sites you work on but most should have a static charging line fitted and these should have a PRV fitted.
    Mar 2006
    66
    92
    Thanks for that, I think we might work for the same company? Had a tee piece go today on a Vulcan fitting, in my area they only went round and redid the tees.
    Jul 2010
    manchester
    212
    i think we do mate !!!!! as far as i am aware they have got rid of the vulcan fitting in the manchester/cumbria area in all Co2 Tesco stores. And as i am sure you are aware sainsburys have the advansor and SCM packs.
    We have no tesco stores with advansor do any tesco in your area have advansor?
    Mar 2006
    66
    92
    only one, we did the install and as far as i know, no problems yet, i have looked at a few vulcan fittings that are over a year old, and they are as rusty as F###, god knows what the inside of them will be like in 5 to 10 years time when the acid in the system starts to take effect.
