22-10-2007, 11:37 PM #1
how can i change the capillary tube
Hi every body i am a new and i want to know how can i repair or change capillary tube in a cabinet refrigerator?
22-10-2007, 11:50 PM #2
Re: how can i change the capillary tube
Welcome,
The answer is that you have to braze it in/out.
But why?
22-10-2007, 11:52 PM #3
Hello
It all depends on the type of fridge.
The short answer is yes you can replace the capilary.
But in truth it is not that easy.
Why does it need replacing? Is it blocked? Is it leaking?
If it is blocked you can unblock it if you have the correct equipment and if it is leaking then dependent on the position then it could be repaired.
More information is required before a full answer can be given.
Cheers taz.
Capillary tube sizing
By Sledge in forum RefrigerantsReplies: 7Last Post: 16-11-2010, 11:44 PM -
Distributor & Capillary tube position
By MrReds in forum Technical DiscussionsReplies: 12Last Post: 29-03-2008, 07:40 AM -
Capillary Tube Needed
By ukengineers in forum CommercialReplies: 3Last Post: 25-10-2007, 02:51 AM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM
