Results 1 to 10 of 10
Thread: keg room
21-10-2007, 02:44 PM #1
keg room
I was wondering when setting the controls of a keg room would the ideal storage temperature of the room be around 7C or could the beer be set at lower temp?
21-10-2007, 03:07 PM #2
Re: keg room
Beer cellars are normally kept at around the 10 deg C point.
If you want it colder the beer passes through a flash cooler that lowers the temp to what you want.
If you try to run the room too cold you get other problems and the expence increases as well.
The evaps are off cycle defrost so no heat is introduced to them.
The rooms tend not to be insulated so heat transfer is an issue when you try to take the temp too low.
Cheers taz.
21-10-2007, 04:24 PM #3
Re: keg room
Thanks taz
22-10-2007, 09:43 PM #4
Re: keg room
http://www.bbc.co.uk/dna/h2g2/A2346266
Have a look here 12 c would be better
Regards Bernard
24-10-2007, 09:47 PM #5
Re: keg room
That is way to warm. Light beer freezes at -1 c because of the higher water, darker beers freeze at -3 c or near. I worked years ago for a company that installed these in the US and I hate warm beer. Each his own.
25-10-2007, 12:48 AM #6
Re: keg room
Hi Bones.
You need to understand how the brewery industry works in the UK.
Beers were traditionaly drunk at room temp (celler temp).
When larger became more and more popular the temp was controlled in the rooms to about 12degC.
In the last 15 years the popularity of cold beer has forced the sale of cold beers at a temp of 2degC.
We refrigerate cellars down to about 10 / 12degC and then the largers are flash cooled down to about 7 degC and 2 degC for the extra cold ones.
Just ask Frank.
Cheers taz.Last edited by taz24; 25-10-2007 at 12:52 AM.
03-11-2007, 09:33 AM #7
Re: keg room
Wow, big difference in the cold one over here. But as long as we are all still enjoying one. I am happy!
03-11-2007, 06:38 PM #8
Re: keg room
03-11-2007, 08:42 PM #9
03-11-2007, 11:42 PM #10
Re: keg room
G'day guys
I have been looking after a lot of clubs and pubs here in Oz for more years than I care to mention. Over here the serving temperature of keg beer at the bar is between 2'C & 3'C otherwise there will be a mutiny by the drinkers in the establishments......
Many years ago one of the main brewers in Oz decided to recommend serving beer at 7'C, as this improves the appearance of beer in the glass with a nice thick, foamy head, and also improves the taste. I cannot tell you the reaction of the drinkers in the first club I altered to this recommendation. I can tell you I was back within the hour resetting everything back to original (2'C).
In the earlier years, keg coolrooms where set to operate at 10'C. The main reason was at this temperature the natural CO2 in the beer build up to a high enough pressure to reduce the amount of bottled gas into the system. At lower storage temperature, the natural CO2 pressure is reduced, and a higher introduced CO2 pressure is required to enable the beer to be pushed through the beer lines to the various bars, which would also cause overcarbonation of the beer, at which point the beer was chilled to 2'C with instantaneous beer coolers (temprites) at the ervig point.
Since then, beer has been recognised as a food product and needs to be stored below 5'C, and therefore different CO2,Nitro gas mixes were tried to prevent overcarbonation. This did not solve the problem of the beer sitting in the beer lines between the keg coolroom and bar, this beer would increase in temperature.
Over here now, everyone is converting to refrigerated glycol systems, which keep the beer chilled from the keg coolroom to the serving tap. Beer is now served into the glass at temperatures down to 1'C in some places. The drinkers demand the colder the better....
Cold room dimensioning - ratio volume air flow
By MrReds in forum Technical DiscussionsReplies: 11Last Post: 17-11-2007, 10:51 PM -
Air conditioning for operating room
By lana in forum Air ConditioningReplies: 17Last Post: 08-04-2007, 08:36 PM -
troubleshoot a two door storage room
By duraid in forum FundamentalsReplies: 7Last Post: 13-12-2006, 06:57 AM -
Cheese Room Design 24V DC
By jbelding in forum FundamentalsReplies: 10Last Post: 02-04-2006, 03:23 PM -
Freezer Room Panels
By Feeze in forum Technical DiscussionsReplies: 10Last Post: 22-04-2005, 05:58 AM
