24-10-2007, 01:38 PM #1
Horsepower needed for 20 ton icemaker
What is the horsepower requirement needed for a 20 ton ice maker . I'm looking at replacing a 10 ton ***** (R-402A) ice machine with a 20 ton ammonia unit .
Is there a formula for figuring this out ??
24-10-2007, 11:03 PM #2
Re: Horsepower needed for 20 ton icemaker
there are good rule of thumbs but it depends on the ice maker brand, and the entering water temp
turbo, vogt tube ice is approx 1.5 ton per ton of ice
at -10 suction with 60 degree water .
northstar style flake is is approx 60 df water 1.3 ton per ton of ice at -25 to -30 df suction.
these numbers work very well for good ice production.
bruce boldy
25-10-2007, 12:00 AM #3
Ta Bruce,
I have worked on a few North Stars, Model 90E's I remember working out the duty of one with a 6WB Mycom on it as we were changing the condenser, this I gave to the technical director and he used a check figure to tell me I was close enough, I now have the check figure.
Autocascade refrigeration system: design verification needed
By DaBit in forum Technical SpeculationsReplies: 3Last Post: 07-02-2010, 07:48 AM -
Smart/As needed evap defrost?
By dkemper in forum FundamentalsReplies: 6Last Post: 27-10-2008, 07:25 PM -
Extra Horsepower From Cooling Intake Temps
By BigJon3475 in forum Technical SpeculationsReplies: 14Last Post: 12-07-2007, 01:37 AM -
Horsepower and Kilowatts
By baker in forum Air ConditioningReplies: 4Last Post: 23-03-2004, 09:17 AM -
Horsepower = Tonnage
By acman in forum FundamentalsReplies: 9Last Post: 31-05-2003, 03:10 PM
