Results 51 to 52 of 52
Thread: thermal Overload
03-11-2007, 09:48 PM #51
Re: thermal Overload
Hello Marc
Have you checked all condenser fan motor thermistors they are on the control loop for the compressor circuit. If you study the drawings you will see that all eight or is it six fans have to be clear before control circuit can be enabled.
You will probably find that one of your condenser fans are seized.
The terminals for these are by the controller on the bottom terminal Blockl.
You can link these out see if this eliminates your problem.
Good Luck
03-11-2007, 10:25 PM #52
thermal mastic
By MOHANDAS RAVI in forum Technical DiscussionsReplies: 5Last Post: 04-09-2010, 04:08 PM -
Thermal Efficiency of Refrigeration System
By hussain316 in forum Refrigeration BooksReplies: 5Last Post: 31-07-2007, 08:59 PM -
Overload tripped lesson
By rosliin in forum DomesticReplies: 8Last Post: 26-06-2006, 03:49 AM -
Setting Overload
By Abe in forum ElectricalReplies: 11Last Post: 06-01-2006, 01:53 PM -
Ransco 7102-1 Thermal Shock Chamber cooling water requirements
By billjduke in forum IndustrialReplies: 15Last Post: 24-07-2003, 08:20 PM
