    Dec 2004
    Weihai,China
    800
    water cooling storage system
    Hi dear sirs
    One hotel facility manager ask me if it feasible to use big water storage tank to keep cooling capacity(by valley electricity) and cut the normal electricity bill.
    I hear little about water cooling storage system. Anybody here can teach me something about this topic.
    Thanks in advance!
    regards
    LC
    AmmoniaMan's Avatar
    AmmoniaMan Guest
    Re: water cooling storage system
    Dear Lc Shi
    Please visit the BAC webpage
    They have good info on Ice Storage application. Tell me if it suits your needs. I think you can download info on applications from the page
    Aug 2007
    Sydney
    52
    1,083
    Hi Lc shi
    I have only come accross two types. Chilled water storage at an embasy who wanted to keep the load very secret - ie we had no idea what the load was. There we used about 2000 litres in two tanks to add capacitance to system to help prevent short-cycling the chiller. The other was in a 40 story building where ice holdover was used. About 2 * 8000 litre tanks were used. The plastic tanks had lots of plastic 20mm pipe inside of which brine flowed through. They ran the chillers at night ( off peak power prices ) to produce an ice bank. Abit like a very big postmix machine that makes fizzy drinks. There is a long payback period for the later, then that depends on how much one pays for the power and how big the system is.
    India
    688
    We have done no of projects wherein the chilled water temp requirements are in the region of 2 deg c. For that we had used Ice bank tank system & it works very well. Infact York too had done similar systems earlier.
    Mar 2007
    India
    38
    Tesla hit the nail on the head. There is no common cure pill for all diseases. You should always break even the investment cost and operating cost. Some pointers from my side are,
    1. Free space around for the tanks
    2. Dual tariffs for electricity (lower during nights)
    3. Penalty for exceeding maximum demand (of electricity) i.e to stagger initiation of equipment
    4. Require lower temperatures
    5. Load pattern is too volatile
    6. Plant capacity is too low for peak loads
    7. If your company anticipates something new from their engineers every time (this is spooky but my last, cash rich, company was one of that kind)
    1. Chilled water temperature requirement is not below +5C
    2. Cost of capital is high
    3. Peak load vs installed capacity doesn't differ by significant proportions.
    4. The power consumption of compressor increases significantly at lower temperatures (why to go upto 0C when you require +5C?)
    5. Increased pumping power (one more pump will be added)
    Dec 2004
    Weihai,China
    800
    Point taken!
    your comment is helpful to me. thanks!
    regards
    LC
    Ukraine
    Dear Lc Shi
    Also you can visit firm buco in the net, this company makes different equipment for ice and ice-water
    Sep 2003
    ISRAEL
    72
    4,248
    Usually the reason is to save energy and cool the water at night.
    For this reason I would check ice storage. this would give you longer time untill the compresors come into work.
    Chemi
    Dec 2004
    LEBANON
    44
    854
    Hi Luchian and Chemi and all . . .
    For cool energy storage I prefer to find a solution (might be glycol) to cool it to a tempreture below the service tempreture from the source so it keeps cool for a longer period when using it.
    Respects and regrads
  1. Water Cooling System Required
    By fletcheraj in forum Commercial
    Last Post: 06-10-2007, 08:34 PM
  2. Fruit Precooling and Storage System
    By Samarjit Sen in forum Technical Speculations
    Last Post: 09-09-2006, 02:42 AM
  3. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
