Results 1 to 10 of 10
13-10-2007, 01:27 AM #1
joining copper to copper, joining copper to brass
Would like to know which is the best type of brazing rod to use for joining copper to copper and copper to brass/bronze.
13-10-2007, 03:18 AM #2
Re: joining copper to copper, joining copper to brass
copper to copper- 15% silver
copper to brass- 45% silver
Those have worked well for me if it's a problem. You can use 15% on both but surfaces must be spotless for copper to brass.
11-12-2007, 03:18 AM #3
35% with reccomemnded flux, works well with disimilar metals as well, like copper to brass or copper to steel or steel to brass.
and definetly agree with big john on 15% copper to copper.
Regards A-Z
11-12-2007, 08:57 PM #4
also clean surfaces of both metals and a wonderful thing called flux
11-12-2007, 11:33 PM #5
copper to copper with sulfos (silver too expensive) , copper to brass with at least 20% silver.http://www.silfos.com/htmdocs/produc...w_to_info.html
11-12-2007, 11:37 PM #6
12-12-2007, 08:37 AM #7
Another brand, many of you may already be quite familiar, but worth repeating is ....HARRIS
http://www.harrisproductsgroup.com/c...gSoldering.asp
Available in most parts of world -I 've seen it stocked up in China and over in Vietnam. Very satisfactory.
regards
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
12-12-2007, 06:07 PM #8
this is a better link and it's spelled phosphorus.
http://www.copper.org/applications/p...rzjts_fill.htmIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
08-01-2008, 08:53 PM #9
For general refrigeration use.
Cu to Cu, Silfos 5 , no flux required.
Brass to copper, with flux.
In both cases the joint should be as clean as possible.
15-01-2008, 02:29 AM #10
