Thread: Small pcb on DAIKIN's REYQ_M
09-10-2007, 05:11 PM #1
Hello again
On REYQ_M7/M8 we always find a small pcb called EB 0336 A7P on the left of the main electrical box above the transformer.
This card is wired on X32A on the main pcb (A1P).
We sometimes use this port to make software updates.
There are 5 leds, bs1/2/3 button and 8 dipswitches onside, see the picture, please.
I'd like to know the main function of this card, i hope someone on RE forum will help.
Kind regards
cool#9Last edited by cool#9; 09-10-2007 at 05:18 PM.
09-10-2007, 09:22 PM #2
Re: Small pcb on DAIKIN's REYQ_M
Hello Cool#9
The green PCB is a data logger. It continually logged all operation data of the system. In case of a fault it holds 1 hour of data leading up to the fault.
I am informed that even Daikin Europe can’t access this data, only Japan can access the data. You don’t actually need the PCB for the unit to work normally. You can disconnect it completely.
Hope the above helps.
Obi Wan.
09-10-2007, 10:00 PM #3
Thanks Obi Wan, simple and clear...
I just had a problem one time with this pcb after a power overcurrent on the field.
DENV just told us they won't be able to deliver a new part and ask to disconnet it but the main new pcb A1P didn't run without it - no more green led flashing ...!
Finaly i send the old one A7P and waited 1 month to get a new one ...
Since my customer is really afraid of Daikin's product, and me too ...
Your's sincerely
cool#9
10-10-2007, 12:11 AM #4
This is strange as Obi has pointed out the board is only a data logger and should not effect the unit from running. I have disconnected many of these to use the power supply for a KRP2A.
11-10-2007, 01:04 PM #5
11-10-2007, 06:35 PM #6
Small domestic absorption fridge
By Peter_1 in forum DomesticReplies: 30Last Post: 24-08-2011, 11:48 AM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Small Chillers
By Sledge in forum CommercialReplies: 6Last Post: 08-05-2007, 05:41 AM -
Building a small refrigerator
By rollerblade12 in forum FundamentalsReplies: 4Last Post: 13-01-2004, 04:02 PM -
How many small strands needed to equal pipe pressure drop?
By DaBit in forum FundamentalsReplies: 17Last Post: 25-08-2003, 09:56 PM
