Results 1 to 8 of 8
Thread: Hotpoint Fridge Freezer
08-10-2007, 10:57 PM #1
Is anyone can give me electrical diagram of Hotpoint fridge freezer model FFA74.My problem is the evaporator fan motor is not working.When i test the terminal going to efm, has no voltage,Only the fridge is getcooling, im not satisfied also because the condenser is cold.i found also there is solenoid after filter drier,when icheck it,it has no voltage.could you give me idea.im very far now in refrigeration,
Thanks,
Cesar
09-10-2007, 12:13 AM #2
Re: Hotpoint Fridge Freezer
Hi Cesar, in the absence of any answers from here try http://www.ukwhitegoods.co.uk/
11-10-2007, 12:03 AM #3
thanks brian to that site you gave me,its helpul but theres no answer in my question,anyway i apprecite it
Many thanks,
Cesar
11-10-2007, 10:28 PM #4
Hi C Bagtas,
Use the search function of this site and you will come up with many answers...
http://www.refrigeration-engineer.co...earchid=322833
and go get a cuppa
15-04-2008, 05:44 PM #5
Hi, I am having the same problem the fan will only spin for a few seconds after the power is restored if left off for a while, The top of the freezer is maybe 0c and the bottom gets down to maybe -5c. The fridge seems to be at an ok temp though there does seem to be a bit of water collecting under salad draws. The link above doesnt seem to work and I am not really sure what I am looking for with the search function, Can you point me to the right thread.
To add I took the back panel off and it was not iced up, I also got a multimeter and there is no power been sent to the fan other than for the few seconds when power is restored.
CheersLast edited by dino2020; 15-04-2008 at 05:55 PM.
15-04-2008, 06:18 PM #6
need to replace the pcb on the unit and it will sort the problem out
15-04-2008, 06:31 PM #7
Is there a specific fault on the pcb as I have a friend who is an electronics engineer and I am sure he would be able to repair it. I am sure he could trace it, but if some one knows what the problem is, I am sure he would appriciate it
So not a thermosat/thermistor problem then?? nothing that cheap Unit is only just over 12 months old, and reading on the net that some people had 3 PCB's in 3 yearsLast edited by dino2020; 15-04-2008 at 07:25 PM.
16-04-2008, 11:41 PM #8
Hotpoint have 5 years warranty on all there appliances but you will have to pay the £90 call out,which is cheaper than a new fridge/freezer
Help Needed - Fridge not working on Hotpoint Mistral FF91
By karlaskie in forum DomesticReplies: 18Last Post: 13-06-2011, 11:49 PM -
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
fridge freezer cooling fan
By bazza in forum Trouble ShootingReplies: 4Last Post: 28-02-2007, 11:33 PM -
Help! fridge freezer probs
By Glenreed in forum Trouble ShootingReplies: 2Last Post: 06-01-2006, 10:51 PM
