    Oct 2007
    scotland
    5
    how to diagnose realy fault
    hi
    I have a fault with a compressor not starting,windings check out fine. relay just clicks, any advise on how to check if relay or compressor at fault. model bm20 aprox 4yrs old
    thanks rossaim
    Aug 2003
    Netherlands
    49
    620
    21
    Re: how to diagnose realy fault
    Back to basic then?
    If the realy just clicks, does it stay on?
    Have you checked, if present, if the fuses are ok?
    Oct 2007
    7
    remove electrics and connect an Annie...check run amps.
    or, remove the relay, put continuity meter across both pin holes and invert it, should make circuit and break when turned back the right way up.if no circuit, relay contacts are shot.
    fit solid state relay to test ...then order new relay if needed.
    Oct 2007
    scotland
    5
    sorry guys
    i said relay when i meant p.t.c. start device
  1. Fault with Tango cassette
    By airefresco in forum Air Conditioning
    Last Post: 19-09-2007, 08:42 AM
  2. UA Daikin Fault Code
    By jedi in forum Air Conditioning
    Last Post: 23-07-2007, 01:44 PM
  3. lg fridge/freezer fault light on function display board
    By bazza in forum Trouble Shooting
    Last Post: 25-02-2007, 03:25 PM
  4. Chiller fault
    By iceman007 in forum Trouble Shooting
    Last Post: 27-06-2006, 06:15 AM
  5. Chiller Fault
    By iceman007 in forum Air Conditioning
    Last Post: 13-05-2006, 07:23 PM
