Thread: Fast learning servisman
08-10-2007, 01:49 PM #1
Hello,
Thaks to the Brian_UK and Taz24 I will learn a lot.
But I have a question for Brian_UK.
In preview post Brian_UK explain me how the use charging cylinders wit single composition gases,
(I realise that charging cylinder for R410a hasn't got),
but what about charging cylinder for R407C gas.Is the same charging procedure(with charging cylinder for R407c)?
And
-How and where to measure subcooling?
I have many questions....
Thank you!!!!!!!
Aleksandar
08-10-2007, 05:31 PM #2
Re: Fast learning servisman
Links
Links 1
And more Links
Just about everything you need is in these links. Tons of info read over them all carefully.
08-10-2007, 09:34 PM #3
Good set of links there Jon, thanks
08-10-2007, 11:42 PM #4
Thank you BigJon3475.
I hope that you will answer me for my questions in
future,thank you again!
By bozicaleksandar in forum Heat PumpsReplies: 3Last Post: 08-10-2007, 01:35 PM -
By bozicaleksandar in forum Heat PumpsReplies: 2Last Post: 07-10-2007, 11:49 AM -
By bozicaleksandar in forum Heat PumpsReplies: 7Last Post: 05-10-2007, 08:26 PM
