    Dec 2002
    Malaysia
    59
    86
    22
    Talking Tube staggered/squared
    Dear All,
    I think that we have digressed from the original query which was tubes and have somehow reached to fins.
    In-line as opposed to Staggered tubing patterns are one thing. And , staggered and flat fins are something else.
    The former is to do with tube sheets - the pattern of holes on the tube sheets define whether the tubes are in-line or staggered. ( In-line is also known as 'squared' due to the outline made by any 4 tube hole s-seen from the side)
    The staggered pattern has obvious heat transfer benefits but only a slight advantage over the in-line but this is at the expense of a slight increase in air pressure drop and a higher bypass factor.
    Why in-line was used I have no idea!
    Jun 2001
    N.Ireland
    1,630
    Hi, bersaga
    cost would be my theory why square tube layouts are used. Also flooded/pumped cooler have deeper coil blocks, so the air will lose more pressure going through the coil, hence if the coil allows the air to flow straight without having to turn less pressure drop is created.
    Also the application, the square coil is used on industrial application, these tend to be larger, with bigger room dimentions and incresed air velocities for rapid blast chilling and freezing.
    Regards. Andy
    Dec 2002
    Malaysia
    59
    86
    22
    Smile Tubes square/staggered
    Makes sense Andy
    Bernard
  1. oxidation scale in copper tube and fittings
    By DeB in forum Fundamentals
    Last Post: 23-06-2006, 09:45 PM
  2. metric capillary tube
    By tralex in forum Fundamentals
    Last Post: 21-02-2006, 06:57 AM
  3. The amazing Mr. Cap Tube
    By shogun7 in forum Domestic
    Last Post: 07-01-2006, 07:33 PM
  4. Cap Tube Sizes
    By Latte in forum Fundamentals
    Last Post: 27-04-2005, 08:16 AM
  5. coaxial (tube in tube) heat exc.
    By aliugur in forum Fundamentals
    Last Post: 04-06-2002, 08:23 AM
