Thread: Cap tubes again
    Jun 2007
    At sea
    367
    Cap tubes again
    Good Morning
    I know this topic has been done to death but I have to replace a cap tube (.026" by 10') and seek a little advice. Can it be joined as the last 12" are built into the accumulator and then it passes inside the evap plates inlet which is aly and I dont want to go there. Also is better to braze it with some phosphor rod or use solder, the heat difference is significant as I have no nitrgen for the purge.
    And last but never the least - I read all the last threads and found aa ancient link from Brian but the URL has has changed so I show the new link below. Its a very good captube page as shows sizes versus flow and not for compressor types. As I can only find 0.031 tube in 8' lengths does any one think 2 lengths of this will do the job or is the centre joint a no no.?
    Chef
    Try www.the-acc-group.com
    and go to commercial products and technical notes
    NC
    262
    Re: Cap tubes again
    Maybe some day these will help.
    Attached Files Attached Files
  1. What kind of tubes to use???
    By Sanel in forum Fundamentals
    Last Post: 05-01-2007, 01:03 PM
  2. capillary tubes
    By JimmyMurphy in forum Fundamentals
    Last Post: 24-06-2006, 07:49 AM
  3. Obstructed Capillary Tubes
    By terrygoodrich in forum Trouble Shooting
    Last Post: 17-03-2005, 02:48 PM
  4. reduce thickness of bended copper tubes
    By rlim in forum Air Conditioning
    Last Post: 08-07-2003, 10:58 PM
  5. Replies: 15
    Last Post: 24-10-2002, 06:52 PM
