Thread: thermal mastic
04-01-2003, 11:47 AM #1
thermal mastic
I WOULD LIKE TO KNOW MORE INFORMATION ABOUT THE USE OF THERMAL MASTIC IN REFRIGERATION. ITS APPLICATION AND ADVANTAGES. ALSO MANUFACTURER OF THE PRODUCT
04-01-2003, 06:11 PM #2
Thermal Mastic
Heard of mastic adhesive and mastic sealer for low temperature applications : specialised silicon sealents for coldstore sandwich panel jointing and to maintain a a leak free installation. I think Selleys have some of them.
04-01-2003, 07:36 PM #3
Virginia KMP makes a heat conducting mastic that improves heat transfer between otherwise unbonded components such as a heat sink to a computer ship or a TEV bulb to the suction line.
02-09-2010, 08:57 AM #4
Re: thermal mastic
When I set ceramic tiles on a wall I will use mastic ... if I am setting natural stone on a wall I will use thinset. That was just the way I learned it. What I would like to know is would it be wrong/bad to use mastic for setting natural stone 6x6 or smaller on a wall?
02-09-2010, 11:20 PM #5
Re: thermal mastic
^^Being refrigeration people we have no idea about wall tiling.
Did you search for this seven year thread just for this???Brian - Newton Abbot, Devon, UK
04-09-2010, 04:08 PM #6
Re: thermal mastic
I have built many frost top counters using TM. I attach copper tubing to 1/4 aluminum plate with clamps as tightly as possible. Since the actual contact of copper to alluminum is small a fillet of TM is then applied to each side of the tubing filling in the gap to improve the transfer of the refrigeration effect to the aluminum. Then, on site, stone is placed on top of the aluminim. TM is used to transfer the effect to the stone. We use a 1/4" notched trowel to evenly spread the mastic on the alluminum and then put the stone on top. It works quite well. Ken
I know there are other ways to do this but That's the way I do it the customers have no complaints.
How do i size a thermal Storgae Vessel(Buffer Tank)
By Tamarco in forum Technical SpeculationsReplies: 8Last Post: 09-08-2010, 09:53 PM -
What's the thermal range of a domestic chest freezer?
By jonno6766 in forum Technical DiscussionsReplies: 7Last Post: 10-01-2006, 10:14 AM -
Ransco 7102-1 Thermal Shock Chamber cooling water requirements
By billjduke in forum IndustrialReplies: 15Last Post: 24-07-2003, 08:20 PM
