Thread: Water Cooling System Required
05-10-2007, 12:15 PM #1
Good day, I wonder if anyone can help - I have a potential job in a hospital, the client wants some type of machine which will supply cooled mains water for a process. The process requires 18 litres per second at 12DegC. The mains water temperature varies and can rise as high as 24DegC due to standing thermal gain.
Ive looked everywhere I can think of but drawn a blank. I'd rather buy some commercial machine than have to start thinking about building something.
Andy
05-10-2007, 03:59 PM #2
Re: Water Cooling System Required
Hi fletcheraj,If you can send me your contact details,I can put you in touch with our sales office in Bradford.We have a lot of experience in this type of application.Thanks,Kevin.
05-10-2007, 05:40 PM #3
Hey 1Torr wot are you doing home at this time??!!! What he really needs is a packaged chiller or an air blast that works and I have just the thing, mind you 18 litres per second thats about 375kW.
fletcheraj can you double check the flow rate as this seems very high for mains water.
06-10-2007, 03:38 AM #4
Hello Fletcheraj !
There are liquid cooling chillers that can take care of that job.
Now cooling water at 18 liters per second ( 285 Gallons per minute ) from 24 C (sometimes ) to 12C is about approx. 250 tons ( quite a few KWs.)
If the temperature drop across the chiller bundle
with the same GPM is less , then you need less KWs.
Greetings
Victorman
06-10-2007, 08:34 PM #5
sounds like the kind of application Star's Indigo chillers would be ideally suited too.
Is the process continuous? ie 24hr?
If not maybe a chilled water storage tank could be used to even out the duty
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Chilled Water A/C System.. antifreeze or no?
By WangFu in forum Technical SpeculationsReplies: 17Last Post: 09-08-2007, 10:36 AM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Building a wine cabinet
