Results 1 to 8 of 8
    Bogadala's Avatar
    Bogadala Guest
    How to calculate duty on the compressor
    Hi All
    I have a requirement to install new deep freezer, which intends to freeze around 300/400kgs of curries, canopies, other food stuff etc from room temperature to -18c in atleast 12 hrs. The size of the proposed room is 3mtrs x 2.6 mtrs by 2.1 mtrs H.
    When considering the above requirement, what should be the condensor Duty in KW.
    Can someone help me please.
    Many Thanks
    Ganesh
    Sep 2003
    ISRAEL
    72
    4,248
    Re: How to calculate duty on the compressor
    Hi Ganesh,
    Start from a COPELAND 301 DLL and work your way up to TEV, evaporator and condenser.
    Good luck
    Chemi
    Oct 2007
    Not Sure?
    Use the modern refrigeration book, it has a section on sizing the system that you are mentioning.
    21
    you could try calling some coldstore companies for 'quotes' they'll be helpful in giving you a calc to size some equipment for you as an option if you run through the details over the phone.
    May 2006
    India
    82
    1,013
    Hello Ganesh,
    First you have to assess the heat load of the system for your application. There are many softwares available. You may calculate the same from Cool Pack or other softwares which the companies provide.
    Once you know the load, you select the refrigeration compressor load, Evaporator loads etc. The Condenser should be equivalent to the heat rejection of the system which will depend on the compressor load, condensing temperature , evaporating temperature and the refrigerant.
    In case you have a problem, please feel free to get back.
    Jun 2007
    South Africa
    80
    Hi Ganesh
    I agree with Samarjit Sen,
    Calculate the heat load based on the max temperature conditions (externally), room size, building materials, etc.
    Thereafter - a compressor, evaporator and condenser can be selected.
    Apr 2005
    Zimbabwe
    41
    8
    wats up gan, i 2 hv è same problem as my freezer is suppose 2 reach -18 in summer bt it cn only gt 2 -10 max and reach -18 in winter.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by donrtc View Post
    Could you translate that in serious English and post your own thread?
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
  5. One Half of a Part Wound Compressor Motor is Burnt
    By aygul in forum Trouble Shooting
    Last Post: 25-08-2003, 11:11 AM
