    Jul 2007
    Indonesia
    38
    30
    Wink Newbies question about Heat Pump
    Anybody has experience about heat pump? [I mean experience of explaining how it works ] Any reference [another reading activity before going to sleep for tonight] would be helpful.
    Feb 2007
    55
    Re: Newbies question about Heat Pump
    In simple terms reverse the cooling cycle.The indoor unit used for cooling becomes the condenser and consequently heats the space.The outdoor unit becomes the evaporator and extracts heat from the outside air.The lower the ambient temperature the more moisture it holds so when the evaporating temperature goes below zero C you will start forming frost on the coil.Therefore you need to devise a defrost system which is usually done by changing the mode from heating to cooling(the outside coil is once again the condenser) the hot gas being condensed melts the ice formed,once this is done the mode is changed back and we start all over again.There are ,of course many variations but that is basically it.
    Hope this helps and don't loose any sleep over it.
    11,025
    Hi Herdian, for some pictures try here...
    http://www.dhclimatecontrol.com/hp.htm
    or if words are your thing..
    http://www.alabamapower.com/energy_k...air_source.asp
    NC
    262
    Jul 2007
    Indonesia
    38
    30
    Use this in the morning to cover my tired eye. Thanks, it is helpful
    Thanks Brian and BigJon3457 ups i mean 3475
  1. DIY heat pump 12kW
    By kimusabi in forum Fundamentals
    Last Post: 17-10-2009, 07:50 PM
  2. frostles heat pump
  3. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  4. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
  5. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
