Thread: light color in cold stores
04-10-2007, 03:53 PM #1
We generally use White daylight tube lights in the cold store. However many places I have seen Yellow colored tubelights. Mostly Europe uses Yellow color by default.
Any reason for a particular colored tube lights?
04-10-2007, 06:45 PM #2
Re: light color in cold stores
Alot of the meat factories i work in have pink lights.
Its to do with discolouring the meat.
CB
04-10-2007, 08:35 PM #3
and go get a cuppa
06-10-2007, 10:22 PM #4
Hi smpsmp45
The best light is that which reproduce the natural sun light. Lignt is very important to identify the color of diferents goods
Normally we use fluorecent bulb(cold weather) for low hight and Metal Halide for more than 5 m hight. That give us a good lingting
07-10-2007, 08:07 AM #5
I came across other reference. The cold store conditions are humid & the visibility of Yellow to human eyes is the max. & hence That is recommended. Even The traffic signals / road marks are yellow for the same reason.
07-10-2007, 09:05 PM #6
If the product is on public display (such as a supermarket) then the owners are very touchy about the light color. It has to do with the light spectrum and the actual product.
As chillin out mentioned, meat display cases are very selective.
If the cold store is for long or short term storage in a distribution facility the color tends to be less of an issue because energy use and heat reduction from the lamps is more important.If all else fails, ask for help.
Temperature pull down in large cold stores( -25 deg c)
By smpsmp45 in forum NH3Replies: 10Last Post: 20-10-2007, 02:56 AM -
Structural columns in the cold stores
By smpsmp45 in forum New to REReplies: 11Last Post: 06-10-2007, 11:42 PM -
Multiple ref. units for cold stores
By smpsmp45 in forum CommissioningReplies: 12Last Post: 21-06-2007, 06:02 PM -
Doorless Cold Stores
By smpsmp45 in forum NH3Replies: 0Last Post: 08-06-2007, 10:47 AM -
lighting in cold stores
By smpsmp45 in forum ElectricalReplies: 0Last Post: 29-05-2007, 01:57 PM
