    HollyT's Avatar
    HollyT Guest
    R-value conversion
    Trying to convert the following from Europe into an R-value which is comparable to American figures:
    R = [(0.004 mq * C°) / W]
    Any idea how to go about it?
    Al Lieberman's Avatar
    Al Lieberman Guest
    Lightbulb
    Try breaking your formula down into their own units and convert each entity individually via dimensional analysis or you may want to refer to various handbooks.
    Jun 2001
    N.Ireland
    1,630
    to convert to American is as follows:
    From To Divide by
    W/ (m) (k) (Btu) (in.)/ (hr) (ft2) (R) 0.1442285
    The 2 after ft is squared, must set my keyboard up properly.
    Hope this helps Regards. Andy.
    St. Louis, MO
    509
    W/m-K is a thermal conductance unit of measurement.
    R values are thermal resistance, and in IP units are typically °F-hr/Btu. Converting from °C/W to °F-hr/Btu:
    1 Watt = 3.412 Btu/hr
    1C° = 1.8F°
    conversion factor: 1.8/3.412 = 0.5275
    Prof Sporlan
  1. Free conversion software I use
    By Peter_1 in forum Tools and Calculators
    Last Post: 23-12-2010, 11:57 AM
  2. Pressure to Temperature Conversion
    By cryptojoe in forum Technical Speculations
    Last Post: 13-04-2010, 12:42 PM
  3. R-22 conversion
    By reefermadness in forum Transport
    Last Post: 24-08-2009, 02:12 AM
  4. Propane Refrigerator Conversion
    By zolar1 in forum Refrigerants
    Last Post: 04-02-2007, 03:42 AM
  5. R12 to R134A conversion
    By northern-tech in forum Commercial
    Last Post: 26-06-2006, 06:24 PM
