    Aug 2001
    1,046
    Single Duct...... AC or heat pump?
    I do like spotting daft anomalies and officials getting involved in what they don't understand is often fertile ground.
    For your amusement, I spotted these two descriptions of a well-known domestic cooler recently.
    This needs some careful thought – especially the heat-pump version.
    [B]“Single-Duct Air Conditioner
    Air conditioner for spot cooling in which the condenser intake air is introduced from the space containing the unit and discharged outside this space.”[/B](Quote from EN 14511 Part one – definition of a single duct air conditioner.)
    No problem there. A ‘single duct’ A/C units is another name for one of those portable things on wheels that you buy in DIY outlets and hang a flexible duct from an open window to discharge the condenser air. They’re coming out of China in container loads these days.
    To my knowledge, they’ve never been available as a reverse cycle heat pump using that arrangement of hoses, though some are available with electric heaters as an option.
    So, how does that become this…………….
    [B]“In a single-duct unit the evaporator (in heating mode) air intake is introduced from the space containing the unit and discharged outside the space.”[/B](Quoted from the Carbon Trust ETPL heat pump criteria for “Single Duct” heat pumps).
    The heat energy source is also the destination.
    Not quite the perpetual motion machine, yet, but getting there……
    The amazing thing is that you can get a tax break (UK only, I’m afraid) if you can locate one of these gadgets.
    3,856
    Re: Single Duct...... AC or heat pump?
    You are meant to put it outside in heating mode with the hose coming into the room......
    Aug 2001
    1,046
    I never thought of that.
    It would certainly explain why they have wheels.
    11,025
    "Put it outside - on wheels"
    Some toerag would nick it before your room had warmed up.
  1. DIY heat pump 12kW
    By kimusabi in forum Fundamentals
    Last Post: 17-10-2009, 07:50 PM
  2. frostles heat pump
  3. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  4. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
  5. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
