    Jan 2001
    71
    HT and LT R22 systems to Isceon MO29 (R422D)
    Hi Guys, I have been asked by a client to quote on some supermarket applications to carry out a R22 gas change. Various refrigerant suppliers have all recommended MO29 as the best choice for both temp ranges.
    I am concerned about the possibility of gas leaks from seals etc......
    Has anybody had any practical experiance of doing gas changes to MO29 ? and if so how was it and did you have any leak problems after ?
    Steve
    Steve
    Aug 2007
    15
    Re: HT and LT R22 systems to Isceon MO29 (R422D)
    Steve,
    R422D is made up from R125, R134a and R600a.
    It has a temperature glide of 4.5 degrees C and a boiling point at atmospheric pressure of -45 degrees C.
    It is an A1 refrigerant, which basically means it is non-toxic and non-flammable.
    It has an ODP of 0 and a GWP of 2230 - ODP is better than R22 but GWP is worse than R22.
    Its standard application temperature range is + 16 to - 18 degrees C but with limitations can go down to -30 degrees C.
    ALL info from Bitzer Refrigerant Report No14.
    Aug 2007
    15
    Bitzer also seem to favour R422A - thats just from a quick read of their refrigerant report.
    It is available on Bitzer's web site if you want it.
    Jan 2001
    71
    MO29 has been used on quite a large number of R22 changes for Asda (So im told) on both temp ranges with no problems.
    The only potential problems I could see would be any shrinkage in valve gaskets / seals which may lead to some small scale leaks.
    I am quite comfortable with the refrigerant as a replacement for R22, its just any practical problems that people may have experianced I am interested in !
    Steve
  1. contaminants in ammonia systems
    By Johnny Rod in forum Refrigerants
    Last Post: 17-10-2011, 05:26 PM
  2. Co2 Systems in Supermarkets
    By 750 Valve in forum Supermarket Refrigeration
    Last Post: 19-10-2007, 08:51 AM
  3. My local Apprentice Training Classes
    By shogun7 in forum Training
    Last Post: 17-03-2007, 03:10 PM
  4. Suction line designing for ref. systems
    By Maxim in forum Fundamentals
    Last Post: 16-12-2006, 05:43 PM
  5. HFCs for flooded systems?
    By garyb in forum Refrigerants
    Last Post: 21-04-2006, 10:02 PM
