Thread: Sea Water for water defrost
02-10-2007, 03:10 AM #1
Dear all,
If we want to use sea water for water defrosting, what material should be used for the coil unit? Or even we shouldnt do this method?
02-10-2007, 06:43 AM #2
Re: Sea Water for water defrost
It has to be cupro Nickel for sure.I hope it is ***** System.
02-10-2007, 10:31 AM #3
Yes it uses *****. How about the coil frame/casing and the fin?
02-10-2007, 01:29 PM #4
By lofic all material should be Cupro Nickel. We had done few projects for navy, when the condenser was fabricated using cupro nickel shell as well as tubes. What ever other materail is used,shall get eaten out in no time.
But making fins of Cupro Nickel is going to be a very torugh task
02-10-2007, 02:02 PM #5
Don't do it.
...and she said "give it to me you big fridgie"
02-10-2007, 03:54 PM #6
Hi There
Just seen your request, i worked on marine projects for a consulting company.
You need to use a plate heat exchanger made from marine stainles steel, one side is sea water the other a closed circuit potable water treated, you will need two pumps a sea water pump with a higher flow than the second pump which is the fresh water pump. you will get quotes from any of the plate heat exchanger manufactures and they need your heat load and fresh water flow td.
You can now make your coils and fresh water header tank from normal materiels, a much cheaper option.
Best Regards Tony l.
03-10-2007, 03:15 AM #7
OK, thanks guys.
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
Hot Water Defrost
By Argus in forum Chit Chat & Service StoriesReplies: 6Last Post: 01-09-2007, 12:41 AM -
open cycle R718 A/C that also provides high purity water?
By star882 in forum Technical SpeculationsReplies: 7Last Post: 27-07-2006, 04:18 AM -
Building a wine cabinet
