Thread: air Condition compressor
29-09-2007, 06:59 PM #1
Hello all
what the power in PSI require from air condition compressor for cooling 12000 BTU.???
Thank you in Advance
Amsahloul
29-09-2007, 10:37 PM #2
Re: air Condition compressor
Absolutely no idea.
The question does not have a sensible answer.Brian - Newton Abbot, Devon, UK
29-09-2007, 10:50 PM #3
Amsahloul,
PSI is a unit for measuring pressure.
Power is generally measured in Watt, whereas 1000Watt = 1 Kilo Watt.
12000 BTU ~3.5kW/h
As a really rough guide you can say that a compressor has a power ratio of 1:2.
Thus, a compressor with a power input of 1.75kW will give you a cooling capacity of 3.5kW.
BUT...
There is much more to the art of selecting a compressor than this.
You really need to take all your figures, this will include temps, flows and so on, and then look at the data from a compressor manufacturer.
04-10-2007, 10:25 AM #4
hello all..could someone direct me to where i can get more information on BTU/kw ratios and how to work out figures for temp,flows etc. many thanks.
Testing Inverters
By fridge doctor in forum Air ConditioningReplies: 38Last Post: 15-06-2011, 06:52 AM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM -
Air condition compressor
By mmtronic in forum Air ConditioningReplies: 23Last Post: 28-07-2007, 03:40 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
