Results 1 to 10 of 10
26-09-2007, 01:53 AM #1
Separate section for humidity problems
I was wondering whether a section for "humidity" problems might be helpful - but then again I suppose I'm a bit biased towards that subject.
It's just that whenever there is a problem which relates to this subject it seems to be scattered amongst all the other sections.
Psychro
26-09-2007, 05:26 AM #2
Re: Separate section for humidity problems
I like the idea of a "humidity control" forum to consolidate the threads into one area. Low temperature humidty problems are always interesting.
26-09-2007, 05:44 AM #3
I have a photograph which has ice on the coil. All the white you see is ice.
18-06-2008, 12:53 AM #4
I've been away from the forum for a while. However, despite liking the newer look, I just wondered if any of the posts in this section were actually taken seriously. It appears that the various categories are exactly the same (I may be wrong of course), but I would like to know if a separate section for humidity problems (perhaps in the Air Conditioning dept - along with Heat Pumps) might not be such a bad idea. I understand that ASHRAE have eventually recognised that humidty (read psychrometry) is a discipline in its own right and even have its own publication on the subject (and about time too).
Psychro
18-06-2008, 04:28 AM #5
18-06-2008, 08:45 PM #6
Fair comment Psychro, I'll give the Guvnor a bump..
19-06-2008, 12:24 AM #7
27-07-2008, 07:36 PM #8
it is a good idea. Coul someone indicate a link or an software download Psychrometric chart in SI UNITS
27-07-2008, 10:48 PM #9
You will see several links to free and not so here:
http://www.refrigeration-engineer.co...ad.php?t=13627
28-07-2008, 11:10 AM #10
Another one available here
http://www.humiditycontrol.co.uk/Tec...tric-chart.htm
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
Separate Forum for Cold Store section
By smpsmp45 in forum Do you have a suggestion for the RE Forums?Replies: 3Last Post: 30-05-2007, 12:17 PM -
Suction pressure problems on TS units at low ambient temps
By nova in forum TransportReplies: 10Last Post: 18-03-2006, 08:35 PM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
