Results 1 to 10 of 10
    Lincoln, England
    37
    Separate section for humidity problems
    I was wondering whether a section for "humidity" problems might be helpful - but then again I suppose I'm a bit biased towards that subject.
    It's just that whenever there is a problem which relates to this subject it seems to be scattered amongst all the other sections.
    Psychro
    Aug 2005
    5,330
    Re: Separate section for humidity problems
    I like the idea of a "humidity control" forum to consolidate the threads into one area. Low temperature humidty problems are always interesting.
    India
    691
    11
    I have a photograph which has ice on the coil. All the white you see is ice.
    Lincoln, England
    37
    I've been away from the forum for a while. However, despite liking the newer look, I just wondered if any of the posts in this section were actually taken seriously. It appears that the various categories are exactly the same (I may be wrong of course), but I would like to know if a separate section for humidity problems (perhaps in the Air Conditioning dept - along with Heat Pumps) might not be such a bad idea. I understand that ASHRAE have eventually recognised that humidty (read psychrometry) is a discipline in its own right and even have its own publication on the subject (and about time too).
    Psychro
    Mar 2006
    India
    74
    71
    12
    Quote Originally Posted by Psychro View Post
    Psychro
    I too think ,it is a good idea to have a dedicated section for psychrometrics.Handling humidity problems is little complex compared to sensible cooling /heating.Many of us can benifit from (easy to locate ) expert opinions.
    69
    10,502
    Fair comment Psychro, I'll give the Guvnor a bump..
    Lincoln, England
    37
    Wink Re: Separate section for humidity problems
    Thanks Brian. Much appreciated.
    Psychro
    Nov 2004
    Sri Lanka
    71
    it is a good idea. Coul someone indicate a link or an software download Psychrometric chart in SI UNITS
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    349
    10
    Quote Originally Posted by patrickj View Post
    You will see several links to free and not so here:
    http://www.refrigeration-engineer.co...ad.php?t=13627
    Lincoln, England
    37
    Another one available here
    http://www.humiditycontrol.co.uk/Tec...tric-chart.htm
  1. Carrier 30XA Liquid chiller Problems
    By Ed Burris in forum Commercial
    Last Post: 13-08-2010, 08:12 PM
  2. Separate Forum for Cold Store section
    By smpsmp45 in forum Do you have a suggestion for the RE Forums?
    Last Post: 30-05-2007, 12:17 PM
  3. Replies: 10
    Last Post: 18-03-2006, 08:35 PM
  4. Oil return problems
    By Peter_1 in forum Industrial
    Last Post: 23-08-2004, 11:30 PM
  5. oil pressure problems on air dryer
    By edge in forum Trouble Shooting
    Last Post: 16-07-2002, 02:10 PM
