Results 1 to 10 of 10
    38
    What compressor?
    Hi all, i'm new to these forums, and i hope some of you are able to help answer some questions i have...
    I have made a couple of R134a systems, all using 1/8hp - average compressors, however, i now want to go a lot further!!
    I am aiming for the magical 'optimum' running temperature of -178°C (or near to)
    some potential gasses..
    Gas Boiling point
    R-14 (-150°C @ 350psi)
    R-50 (-162°C @ 450psi)
    R-740 (-120°C @ 300psi) argon
    However, i haven't a clue where to start off, by finding a compressor capable of handling these temperatures and pressures without forking out thousands of pounds on a cryogenic system
    can anyone please help?
    James
    Apr 2006
    1,620
    Re: What compressor?
    No offence but clearly you have no idea about what you want to play with. Keep learning and you'll get there.
    Now a more direct answere is there are non you either fork out the cash or learn how to make cascades and there is a ton you'll need to learn to do that safely and reliably.
    Not Sure?
    I would say it would almost impossible to get that. Why? because you are in liquid nitrogen territory. If someone made a "reliable" system then they would already have it out. These compressors are custom made with oil loops and extended discharge piping in the compressors. Not a stock item. Good luck to you!
    Nov 2006
    63
    392
    Your talking very dangerous territory here, the pressures you are talking about are way beyond standard refrigeration kit and should you try it you waould have a big hole were the plant used to be if anything went wrong.
    What are you trying to cool?
    Ian
    vwxy950's Avatar
    vwxy950 Guest
    Cool why almost all women have many handbags
    Handbags have been a good accessory in completing women's outfit. There are a wide variety of handbags that come in different styles, designs, materials, colors and sizes. These accessories have great significance because of their versatility features. Both men and women carry bags, however, it is just well-known that women use them more than men. Furthermore, handbags are also use to create a fashion statement. Different designs and styles are born each year. Celebrities and popular TV icons are often the first to try trendy handbags to complete their looks.Different variety of handbags were basically designed for different purposes. And to make it widely available to everyone, such fashion accessories are now available in different variety of designs, styles and colors to incorporate with different wardrobes. This is the reason why almost all women have 3-5 different types of handbags in their closet
    Nov 2005
    New Zealand
    550
    Re: why almost all women have many handbags
    Quote Originally Posted by vwxy950 View Post
    What the hell has this got to do with the price fish
    Norm
    LRAC's Avatar
    LRAC is offline Veteran Poster I am starting to push the Mods: of RE
    Sep 2006
    Midlands
    453
    Quote Originally Posted by Toosh View Post
    Norm
    Handbags, now fish i suppose the handbags might withstand -178 C until you touched it and fish is very expensive at the minute?
    Grumpy men live longer
    Nov 2008
    Ireland
    I work on factory built autocascades for the semiconductor industry, I have been to the plant in Sharon, Boston USA where they are built, the cascade plumbing assembly is an extremely complex affair, made by a specialist copper tube fabrication house, the compressors used were the Danfoss LTZ/NTZ series and the gases used are typically R134a, R14, R336fa. These older systems achieve typically -70C and are critical charge systems. The company have been working hard on a -95C autocascade using a scroll compressor, and it has been in production only for the last 2 years, I have met some of the top refrigeration design engineers there and they feel that they are pushing things to the limit a bit, tryint to keep ahead of the competition. My point is, that if a major player in autocascades is having to put so much time/expense into getting these low temperatures, then it is beyond the reach of the everyday guy to build such extreme systems safely.
    Oct 2002
    Hampshire
    156
    22
    Hi, -178°C, thats bloody cold lol.
    I have seen a few cascade systems reach -130 on four stages for pc chips and that was using normal hermetic compressor, I think reaching the temperature you desire is going to cost you big $$$$$£££££ money. Good luck :]
    Jul 2010
    usa
    40
    thanks for your post i am looking for that
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. Compressor pumping efficiency
    By shogun7 in forum Fundamentals
    Last Post: 25-02-2004, 10:50 PM
  5. One Half of a Part Wound Compressor Motor is Burnt
    By aygul in forum Trouble Shooting
    Last Post: 25-08-2003, 11:11 AM
