Thread: Training help
    sutt777's Avatar
    sutt777 Guest
    Training help
    Hi all
    I am a time served electrician, been out of the game quite a while but am returning to the job. Could someone please tell me the training/requirements I would need to install simple split aircon systems. I would be up to date on all the elec side, so just the basics for these systems.
    Thanks in advance
    Jan 2003
    East Anglia
    1,160
    Re: Training help
    Sutt777
    C & G Gas Handling is a must, although normally you wont have to touch the gas when installing a split, just opening the valve once the pipework is vac'd you may need to top it up on longer systems. Braising courses are also good, not only to teach techniquem but also H & S issues and the use of nitrogeon purging when braising. I am glas to see you are looking at getting trained properly and not just jumping in. All the best with your future employment and of course there a lots of us on the forum for when you run into problems
    fatboy
    Feb 2007
    2,473
    45
    Re: Training help
    Don't worry M8, you don't need any additional training.
    Feb 2007
    2,473
    45
    Re: Training help
    NOTE:
    The previous message was "tongue in cheek"......
    I as an experienced A/C engineer has been asked by a friend if I can rewire a couple of houses for him, should be simple, just a couple of Dist boards, cabling, sockets and so on.
    As I already got 20+ years as an engineer (admittingly in another field) it shouldn't be a big problem, should it?
    To answer your question..
    A minimum of 2 years (accelerated) day release collage, together with working beside an experienced A/C guy.
    sutt777's Avatar
    sutt777 Guest
    Re: Training help
    Appreciate the fact that it is a time taken skill to install aircon and am not demeaning it, I understand training will be required but, I am talking of reasonable striaght forward aircon systems, nothing too complicated.
    What by LAW am I required to have.
    I am not going to become a full aircon engineer, just handy to be able to offer domestic aircon should customers require it, would like to know how to do it properly and not destroy the planet in the process.
    sutt777's Avatar
    sutt777 Guest
    Re: Training help
    And rewiring a house is v simple in electrical terms, am sure you are more than capable of doing it.
    Doing a multiple 3 phase install using pyro and enhanced safety glands in a petro-chemical explosive area is a damm site harder.
    However part P is required by law or at least the install checked and certified by part P qualified electrician is required by LAW for a simple house install.
    Just asking if there is a similar requirement in your industry
  1. Lack Of Training Centres
    By Latte in forum Training
    Last Post: 06-11-2008, 02:56 PM
  2. CO 2 training possibilities
    By DubbelJoe in forum CO2
    Last Post: 17-05-2007, 05:13 PM
  3. Whats expected from training?
    By taz24 in forum Training
    Last Post: 28-11-2006, 08:50 PM
  4. Training Problem.
    By dogma in forum Training
    Last Post: 03-09-2006, 11:24 AM
