    Magic's Avatar
    Magic Guest
    Question centrifugal chillers york
    I,m working with a 360 ton centrifugal chiller and im having trouble determing if its low on refrigerant charge.This chiller uses Refrigerant 134-a.I am not sure what is the correct operating superheat or subcooling of this unit.Can someone tell me what is the best and most reliable method to determine if this unit is fully charged If you guys need anymore information on the chillers operating data to help me solve my problem just let me know.I really need to know if the chillers working correctly and efficiently.
    Apr 2006
    uae
    45
    Re: centrifugal chillers york
    sir,
    check unit manual or name plate. it shows how much you need to charge.
    regards,.
    Feb 2004
    132
    The nameplates are an estimate, not even close in many instances.
    Quote Originally Posted by joel View Post
    sir,
    regards,.
    Apr 2006
    uae
    45
    Quote Originally Posted by absrbrtek View Post
    sir,
    superheat required is 1- 2 deg.F...
    pls...consider checking your...
    cooler/cond flow and approach.
    regards
    Mar 2007
    57
    15
    Hi Magic.
    would check refrigerant level in sight glass on evaporator, check delta t across evap and cond, and check operating pressures for your application,
    onquin's Avatar
    onquin Guest
    is there liquid refrigerant valve actuator installed in your unit?try to check its operation,eventhough you are having the correct amount of refrigerant in the system,calibration and proper operation of that valve and level sensor is required,
    Oct 2009
    merida mexico
    282
    15
    measured the evaporator at 100 % capacity between the output of water and saturated evaporator temperature performance should be of 2 ° f.
    Best regards
  1. Big Centrifugal chillers
    By 404cab in forum Industrial Compressors
    Last Post: 17-12-2007, 08:06 PM
  2. york gs/ gsi chillers
    By GHAZ in forum Technical Discussions
    Last Post: 16-09-2007, 10:42 PM
  3. York Centrifugal
    By Peter_1 in forum Industrial Compressors
    Last Post: 14-08-2005, 01:25 PM
  4. Centrifugal chillers part 2
    By reggie in forum Industrial Compressors
    Last Post: 16-05-2002, 09:07 AM
  5. Centrifugal chillers
    Last Post: 02-05-2002, 07:22 AM
