Results 1 to 27 of 27
Thread: Service checker Daikin
19-09-2007, 04:20 PM #1
Hellow friend Techs,
This is my first post here and I hope I will learn a lot here and that someone can help me with my first problem.
When a Service-Checker has been connected for some time on a Daikin VRV, can the stored data's be exported to an xls file so that it can ve viewed in xls Excel ?
Can the data's be exported to another format (pdf, Dbase,...)?
Is there a viewer available for the colelcted data's?
Or do you simply need the complete software to view all the data's in a graph environment?
Is the software available for sale? It is not my intention to use it direct to a Daikin unit - I don't have the converter anyhow and I even don't need it - but I only have to look in millions of collected data's.
Daikin gave them to me in a printed format but I have +/- 15,000 pages full of data.
This question is most likely for someone who uses the Service Checker.
19-09-2007, 05:14 PM #2
Re: Service checker Daikin
Welcome to RE, I hope you enjoy the forum and will abide by the rules.
What format is the data in?
You need to know what extension it uses, (.html .pdf .???)
What was the suggested software?
and go get a cuppa
19-09-2007, 10:52 PM #3
Hi Cool (That's a trade name somewhere methinks!) and welcome to the forum.
Sorry, I can't help with your problem but I'm sure someone out there has come across it before.Brian - Newton Abbot, Devon, UK
19-09-2007, 11:12 PM #4
Hello there
I purchased a checker 12 mths ago and they sent me the software for it on floppy discs. These were completely useless so I called up and they send me a CD ROM. I think you may be able to download updates somewhere as well.
Good luck!
19-09-2007, 11:15 PM #5
What is the name of the software?
What is the file extension?
More info about the file please?
Any chance of sending me a small sample of a file?
and go get a cuppa
19-09-2007, 11:47 PM #6
Well, the software would be Service Checker I,II or III.
I know Toshiba has mucked around with their DynaDoctor software to prevent this "unauthorised" viewing of the data.
But I never had a reason to check the service checker's file system, I will do it tomorrow when I get in to the office, unless someone post the answer before then.
19-09-2007, 11:54 PM #7
I don't know whether this guy is still about but might be worth checking..
http://www.refrigeration-engineer.co...ead.php?t=4862Brian - Newton Abbot, Devon, UK
20-09-2007, 08:58 AM #8
Hi Cool,
For your question, the data recorded by the Daikin Service Checker can be converted to the *.csv format file. This format can be opened easily by Excel.
For more detailed information you can send me a private message.
20-09-2007, 07:13 PM #9
Thanks Chillin Out
20-09-2007, 08:02 PM #10
Viking, I should be very grateful if you just could try if you can export these data to whatever datafile, for example csv.
This software is as good as useless without the proper converter.
So, is the software then not available for purchase?
21-09-2007, 05:28 PM #11
Hi cool100
With service checker you can easily export to csv format and then to Access or Excel.
There's no viewers and as i now you need to open the build in software.
If you have an old version of software try the HELP section to find a link for the updates.
Regars
cool#9
22-09-2007, 09:08 AM #12
I'm interested too.
22-09-2007, 11:49 AM #13
No, Sorry.
Our laptop and service checker had to go out on a breakdown, so I haven't had a chance to do it.
But I will, I promise.
22-09-2007, 07:54 PM #14
I have a service checker and an appropriate software.
If you send me the files i'll return them to u in a .csv or .xls formats
16-04-2008, 01:07 PM #15
Hi everyone,
I am a virgin poster so apologies if I am in the wrong forum etc.
I am thinking about purchasing a service checker for Daikin VRV's but have heard about the Coolmaster 1000, does anyone know which is the most user friendly?
Thanks in advance!
17-04-2008, 10:15 AM #16
CoolMaster is a simple RS232 Gateway. What you mean is probably CoolAnalyzer. However,
CoolAnalyzer and Checker have quite different purposes. If you need to perform a detailed "deep" diagnostics you better use Checker. But if you need quick diagnostics without connecting Laptop, using CoolAnalyzer may be very convinient. It is also very useful for commisioning since you can read all the required data and malfanction codes from the outdoors.
17-04-2008, 10:22 AM #17
you can save as cvs files then view them and also convert to bar graphs you can download upto date software from daikin web site for free daikin recomend checking for up dates every 3-4 weeks
29-11-2008, 02:41 PM #18
Dear Sir
would you please help me to find where from we can buy Daikin Service Checker and CoolAnalyser
Thank you in advance for your prompt reply
Kind Regards
29-11-2008, 03:40 PM #19
Service checker can be bought at your local Daikin Distributor.
For CoolAnalyzer just google for CoolMaster 1000....
30-11-2008, 02:53 PM #20
Thank you for your reply, and actually I got a quotation from CoolAnalyzer. Is CoolAnalyzer can be used instead of Daikin Service Checker? What is the difference. Do you have any training program for commissioning of Daikin VRVIII?
26-10-2010, 05:09 PM #21
hola el enlace para actualizar su software es AIRNET.JPN/CHK/ENG nombre de usuario:chk2009 contraseņa:151209 los archivos se pueden exportar en formato csv y luego con el programa los abrira
17-11-2010, 08:07 AM #22
Thanks! Login and password is correct
03-01-2011, 04:05 PM #23
The password doesn't work right now.
Doea anyone know the current one?
Ver. 1.50 has now been released (Dec 2010) which connects to the HT Altherma.
24-02-2011, 07:36 AM #24
Does anyone have ver 1.50?
Thanks alot.
24-02-2011, 03:12 PM #25
Daikin technical can email it out if you contact them.
18-03-2011, 10:22 PM #26
I dont believe 1.50 is available yet, and i dont think Daikin will send it out. 1.18 is the latest
22-03-2011, 12:53 PM #27
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin & Toshiba Service Manuals
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 13-08-2010, 06:17 PM -
Daikin, Why do we bother?
By gwilliamson in forum Air ConditioningReplies: 21Last Post: 02-02-2010, 09:38 AM -
Service Checker Tool
By KISS KISS BANG in forum New to REReplies: 3Last Post: 04-05-2009, 10:53 PM -
Daikin VRV Checker
By bobjob in forum Air ConditioningReplies: 6Last Post: 04-01-2009, 08:10 PM
