Thread: old traulsen defrost timer
19-09-2007, 03:50 AM #1
Hi, I have an older three door traulsen freezer in our resturaunt.The model is G32010WM.I just Put a new defrost timer on it.The old one was set for 3, 40 minute defrost cycles.Is this the normal settings.Also does anyone know where I could get a copy of an owners manual for this model.I tried the Traulsen web site ,but they never got back to me.
Thanks for the help
19-09-2007, 09:20 PM #2
Re: old traulsen defrost timer
Scott,
Have you replaced 'like for like', or are the defrost timers different?
The defrost will be either electric or hot gas, and 40 mins sounds a bit long for a heating cycle defrost, unless the system (sometimes the time clock itself) has a means of terminating the defrost early as the temperature rises. I would have expected more like 20mins.
Hope this info is of use.
Adrian.
20-09-2007, 12:59 AM #3
Hi,and thanks for the reply.yes I replaced it with the same thing,8141-00 Paragon,It seems to be working ok.Before it was feezing up.The points looked kind of shot.Would it be maybe when it went into defrost mode those points were not making contact?
scott
26-09-2007, 06:03 AM #4
Hi there,
Yes, this is fairly common on defrost timers. The contacts can become a little toasty over time and intermittently make contact. I usually set the defrost for 4 times a day and - yes 40 min intervals. This particular model has a defrost solenoid to terminate the defrost if the coil reaches the defrost limit setting usually about 55 degrees.
good luck, fire and ice
paragon defrost timer 8145-20
By kengineering in forum CommercialReplies: 4Last Post: 20-10-2009, 02:55 AM -
Maytag side by side auto defrost problem
By m0t in forum DomesticReplies: 4Last Post: 02-06-2008, 12:47 PM -
By scott777 in forum Technical DiscussionsReplies: 2Last Post: 02-09-2007, 02:08 AM -
Hot gas defrost vs Electric defrost
By herdian in forum IndustrialReplies: 19Last Post: 13-08-2007, 11:25 PM -
Hot Gas vs. Electric Defrost
By herefishy in forum Technical DiscussionsReplies: 26Last Post: 08-03-2005, 07:50 PM
