Thread: Capillary Tube Needed
18-09-2007, 11:06 AM #1
We need a capillary for a Frost Trol Bali 12L but we cant seem to get it or an alternative in England. I have included the manufacturers sizes and the unit is running on R134a
If the refrigerant is R-404, there will be 2 capillary lines in the cabinet. The dimension is 1.68cm, the hole is 1.25 mm and the diameter is 2.45mm. Then, if the refrigerant is R-134, the capillary is 4,80cm. The hole is 1.5mm and the diameter is 2.5mm.
Can anyone help??
Thanks Lisa
18-09-2007, 12:15 PM #2
Re: Capillary Tube Needed
Have you tried your wholesaler yet?
24-10-2007, 10:24 PM #3
Supco makes a great captube and they have a handy sizing chart with it to help you cut the right length.
25-10-2007, 02:51 AM #4
Cap tubes again thread for conversion charts
Capillary tube sizing
By Sledge in forum RefrigerantsReplies: 7Last Post: 16-11-2010, 11:44 PM -
Distributor & Capillary tube position
By MrReds in forum Technical DiscussionsReplies: 12Last Post: 29-03-2008, 07:40 AM -
Capillary tube prices in the UK
By trial in forum FundamentalsReplies: 4Last Post: 18-09-2007, 12:16 PM -
:rolleyes: capillary tube size in distributor?
By abbasi in forum New TechnologiesReplies: 2Last Post: 08-07-2006, 03:56 PM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM
