Thread: Ge
    oel's Avatar
    oel Guest
    Ge
    Hello, I have an General Electrics side by side Freezer/Fridge. On the Evaporator there are two (2) defrosting thermostats in series with the defrosting heating coil. Can anyone enlighten me why there are two of them?
    May 2002
    TN
    124
    23
    In case 1 defrost termination breaks, you will not melt the plastic around the evap. Maybe GE had a problem with that and add an extra 50 cent part.
    PMQ's Avatar
    PMQ Guest
    MAY BE A FAIL SAFE SET UP ? IF ONE STICKS THE OTHER WILL STILL BE IN CIRCUIT.A BIT LIKE A SAFETEY STAT !! ??
    Doc's Avatar
    Doc Guest
    Smile
    The second defrost sensor you mention is probably the thermal fuse. It is wired in series to protect the cabinet against damage from the heater. If the defrost sensor fails then the thermal fuse will cut power to the heater. Normally operates at a temperature between +72 and +84C.
