Results 1 to 1 of 1
17-09-2007, 12:25 AM #1
Estimating savings for low-e glass
I need help estimating the seasonal cost savings for installation of low-e glass vs clear glass. The window has 45 square foot of area and it faces due West. It is 3/16" thick each sheet with 3/8" air spacing. It has no shading. This would be located at N 39* W 77* Lattitude, longitude. This is near Washington DC.
I had a contractor replace this glass due to seal failure. It appears that despite contractual obligation, he did not install low-e glass but rather used clear glass. I've checked it by viewing a burning match reflection. All four surfaces appear identical. The low-e unit that was removed had an obvious difference in reflection from the coated surface.
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
Leaking sight Glass!?!!
By The MG Pony in forum FundamentalsReplies: 10Last Post: 19-04-2007, 06:09 AM -
liquid line sight glass mystery
By austech in forum Technical DiscussionsReplies: 19Last Post: 18-07-2006, 08:16 PM -
Helical condenser (for glass door refrigerators)
By Guilherme in forum DomesticReplies: 1Last Post: 22-04-2002, 01:43 PM -
Sight Glass Located
By Abe in forum Trouble ShootingReplies: 3Last Post: 22-01-2002, 01:22 AM
