Results 1 to 10 of 10
    Somerset
    69
    4,698
    Citb Or Not Citb
    Hi to All.
    This is primarilly a question to those of us that hold a U.K. Ammonia safe handling Certificate.
    For a long time I had been renewing my C.I.T.B. SAFE HANDLING CERT. Every 3 yrs (as reqd.)
    Untill it was pointed out that if I did the City & Guilds
    version. I would not have to renew it every 3yrs.
    So almost 3 yrs ago my Collegue and myself sat the C&G Closed book exam and duely received our certificates.
    Imagine my supprise when our depot manager contacted us to say. The training company where we had sat this exam had phoned him to say our Certificates were due for renewal as it would be 3 yrs in Feb 2008.
    I have scanned the C&G Web site and can find no recall or update details requiring a resit?
    The only referance I can find is that it says Some Companies like their employees to retake this 3 yearly
    Has any one else a similar experiance or any views on this
    Aug 2001
    1,046
    Re: Citb Or Not Citb
    I should point out that this is a UK only qualification.
    To my knowledge the C&G assessment certificate is valid until there is a change in technology or practice that results in a change in their assessment procedures.
    This is the case for the F gas version, and I presume it is also the case for ammonia. As it’s issued by C&G, I suggest that you contact them. If they say it’s valid for an indeterminate time, then it’s valid.
    The CITB version on the other hand is valid for 3 years and needs a re-assessment after it expires.
    I know you asked about ammonia, but in fact the F Gas version of either is now a requirement to work on any of the F Gases, CFCs, HCFCs and HFCs in the UK and other EU countries.
    In my opinion, the possession of qualifications to work on ammonia and hydrocarbons should be separate and stand-alone qualifications, distinct from the two assessments that are used in the most part for the conventional refrigerants.
    As the new F Gas laws will require a mandatory leakage check, and the possession of a valid assessment certificate is used to enforce the new law in the UK, it’s probable that there will be a change in both the assessments soon to take this into account.
    Employers are entitled to require a periodic re-assessment of either if they wish, and it’s not a bad idea.
    But they should be prepared to pay for it if it is not a requirement of the certificate.
    Hope this helps.
    Oct 2006
    1,843
    21
    Hi to All.
    As Argus says the qualification is valid unless they bring in new legislation changing the rules to which we must abide by.
    As long as you have not killed anyone by deliberate release into a shopping centre or some such place you do not need to retake it.
    Cheers taz.
    Somerset
    69
    4,698
    Thanks for your prompt replys Taz 24 and Argus.
    Just to clarify what I was asking.
    Basically had any other of our Ammonia Engineers been approached regarding resitting C&G SAFE HANDLING OF AMMONIA / CHARGING A SYSTEM which is 2078 parts 3&4.
    Not to be confused with SAFE HANDLING OF REFRIGERANTS / CHARGING A SYSTEM which is 2078 parts 1&2
    Therfore there are 2 distinct Certificates regarding Ammonia and other Refrigerants.
    C.I.T.B. also has the same 2 distinct catagories but, as has been stated these have to be resat every 3 yrs!
    Thanks Grizzly
    Oct 2006
    1,843
    21
    I can't answer that obviously.
    no one should need to retake the 2078 1,2 or 3,4.
    if providers are telling engineers that they need to then they are either very confused or misleading the customer.
    Yes ammonia is seperate to non ammonia whether C&G or CITB.
    Cheers taz.
    Aug 2001
    1,046
    You aren't making your point clearly understood.
    As I said in my reply, check it out with C&G, as appropriate. They are better positioned to give you a definitive reply.
    The parts 3 & 4 of the C&G assessment should obey the same rules as parts 1 & 2 unless they state otherwise. In otherwords if they say it has a 3 year life and 1 & 2 are open ended, then that is what it it is.
    Secondly, even though C&G issue a ‘perpetual’ certificate, good for the scope-life of the course, employers have a right also to demand (and pay for) a re-assessment.
    Equally, you have the right to refuse if your certificate is still valid.
    Oct 2006
    1,843
    21
    Quote Originally Posted by Argus View Post
    Thats a good point Argus.
    It may be the company requesting the reassessment?
    In which case as part of there employment terms they may require you to be assessed reguarly to prove ability?
    I do not know your situation but C&G do not require a reassessment and that comes from a C&G assessor.
    Cheers taz.
    Somerset
    69
    4,698
    Thanks for the Info Guys
    Feb 2006
    derbyshire
    610
    Red face Re: Citb Or Not Citb
    good info guys, dont mean to be a wet wrag but has anyone heard the rumour that CITB [thats our outfits choice] and C&G will soon not be enough to satisfy europe and a corgi type scheeme will be required that will be alot more intense and expensive in money terms and time.
    Oct 2006
    1,843
    21
    Quote Originally Posted by old gas bottle View Post
    It's been heading that way for years unfortunatley.
    Soon he mininimum requirement required is level two and then in the near future it will be level 3.
    taz.
