Thread: R134a Vs R404A
14-09-2007, 10:31 AM #1
R134a Vs R404A
Hello! I'm new here..
Can you tell me the comparison between R134a Vs R404A specifically for truck refrigeration system application in Middle East? Thanks.
14-09-2007, 04:45 PM #2
Re: R134a Vs R404A
Just look at the Pressure temperature charts. For automotive and air cooled, the condensing pressures will be pretty high. Most automotive A/C is R-134a. I'd use R-134a down to about 0 dF. Below that you will need to switch, I'd prefer R507 over any of the 400 series.
Ken
Ken
20-09-2007, 07:30 PM #3
Re: R134a Vs R404A
R134 is designed for what is called high/medium temp jobs such as chillers R404 is for lower temp work ie freezers. If its for "middle east trucks" then look to see what the supply is for these gases in the middle east and what units you fit to what is recommended by manufacturer.
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R134a or R404a
By jingua_ph in forum RefrigerantsReplies: 4Last Post: 27-09-2006, 03:31 PM -
R12 to R134a
By fireblade in forum DomesticReplies: 15Last Post: 19-08-2006, 09:02 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM
