11-09-2007, 01:02 AM #1
calculating the kw's my unit is doing.
hey everyone I need help calcualating how my kw's of refrigeration the new pakage unit I just installed is doing. The tradesman I work with has set it as my home work but I have lost one of my main tafe books and cant find any formulas. Can anyone please help me. All im after is the formula so I can work it out on my own. But we had 19.2 air on the coil 27.7 air off the coil with an air flow rate of 2350L/s. on heating of course. Sorry if this is in the wrong section im a newbie. Thanks for all your help
chris.
13-09-2007, 04:36 AM #2
Re: calculating the kw's my unit is doing.
I have yet to know this forum policy about homework questions. Most of the professional forums on the net either don't allow it or have separate forums. Till the time I know it, here is the formula for you.
Take pains to remember this forever if you continue to be in HVAC. The sensible heat can be calculated by Q = 1.1xcfmxdT, where Q is rate of heat flow in btu/hr, dT is temperature difference in F.
Go and get an excellent and free unit conversion software called Uconeer from www.katmarsoftware.com
Good luck,
13-09-2007, 06:14 AM #3
Watch out as one of your tafe teachers may be lurking here!!
Q=M x C x ∆T
where Q= amount of heat produced
M=mass of air flowing
C= specific heat of air
∆T=delta T or temp difference
google for more info there is lots around.
Go search the secondhand bookshops library for a copy of "Princinples of Refrigeration SI edition" by RJ Dossat it is indispensable.
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
Off-line Mitsi VRF leaks!
By sinewave in forum Air ConditioningReplies: 8Last Post: 05-06-2007, 11:18 PM -
Help with a dreaded LG unit..
By marc5180 in forum Air ConditioningReplies: 18Last Post: 17-03-2007, 10:24 PM
