Results 1 to 30 of 30
Thread: Mitsubishi compressor lock
12-09-2007, 12:11 PM #1
Re: Mitsubishi compressor lock
Intelligent Power Module.
So you get the flashing lights of incorrect order and they are staying on for a while before slowly dying out?
edit: also ozairman, on the unit that failed the LED tester, were all the diode readings OK both ways?
edit2: And was the IPM faulty, or the control PCB that times the IPM, or both?Last edited by paul_h; 12-09-2007 at 12:30 PM.
12-09-2007, 12:21 PM #2
What I'd like to know is why they sometimes call the inverter compressors "DC compressors" - when you're feeding them 3 live feeds, U/V/W - surely that just means that they're 3ph compressors?
I once had a 3ph motor and a single phase to 3ph inverter that I was going to utilise as a lathe motor but never got round to actually doing it, so sold the motor/inverter package on eBay.
Would it not be possible to use a single phase to 3ph inverter to test run the 3ph / "DC Compressors" in the field? (by-passing the a/c unit's driver altogether)
Just a thought
12-09-2007, 12:24 PM #3
I get ligts 1,4 and 6 come on thenall 6 come on then lights 1,4 and 6 come on again and then all 6 come on then and they stay on. The lights never go on and iv left it on for well over 2 mins.
If the IPM was faulty though surely i would have different voltage down each phase to the compressor but iv not, they are all 80volts.
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
Mitsubishi electric scam
By Renato RR in forum CommissioningReplies: 9Last Post: 21-08-2007, 07:59 AM -
Mitsubishi SRK
By daddymac in forum Air ConditioningReplies: 1Last Post: 26-04-2007, 08:47 AM -
Mitsubishi problem
By marc5180 in forum Trouble ShootingReplies: 15Last Post: 17-01-2007, 10:06 PM
