Thread: Old FORSTER frige
10-09-2007, 11:07 AM #1
Old FORSTER frige
Hi All
There's a 17-year old Forster Frige in my mate's shop and it uses R12 .
The question is:
What's the best drop-in (I use RS24 for my MK2 Golf Gti) for re-gassing?also I re-gassed my car by liquid charge through high pressure port but there's only
one service port(low side port?) on the hermetic compressor.
regards
Kwan
10-09-2007, 07:22 PM #2
Re: Old FORSTER frige
Did you use a blow torch on the can?
You should normally charge a system through the low side, if you add it in small parts at a time you can still charge as a liquid.
and go get a cuppa
11-09-2007, 06:21 AM #3
R49 (R413A).
Trevor
11-09-2007, 09:27 AM #4
R409A,R416A for medium temp
R134a, R416A for auto
11-09-2007, 12:44 PM #5
R401A or R409
For R134A you must change oil. It could be difficult.
11-09-2007, 08:43 PM #6
i take it, so R409A can be mixed with R12,is that all
03-10-2007, 09:50 PM #7
r413a mate
absorbtion frige fault
By marc in forum TrainingReplies: 1Last Post: 29-03-2007, 09:48 PM
