Thread: 'Close-Control'?
07-09-2007, 03:41 PM #1
'Close-Control'?
Can i get some of your definitions of 'Close-Contol' systems/technology/market etc.
07-09-2007, 04:45 PM #2
Re: 'Close-Control'?
"Close control" or "full function" units are commonly seen in computer/communication/IT rooms.
Normally they would be able to:
Cool (obviously)
Humidify
De-humidify
Heat
07-09-2007, 05:03 PM #3
CCU's can be dx or with cooled water from a chiller.
Most of them, when dx,have all the components indoor, such as control, compressor etc. and only a condensor outside.
For an example, check: http://www.trane.com/webcache/rf/com...4_08012002.pdf
09-09-2007, 09:17 PM #4
...thanks for the posts.
is there a large demand for skills on these systems as IT becomes more & more important to businesses?
what companies are established/big names in this field & whats gases commonly used?
09-09-2007, 09:47 PM #5
Don't know about the UK, but in Holland just having STEK is enough.
In Holland the bulk is Trane, Stulz, York and Liebert, as far as I know.
Most of them use R407c on the new ones, the older ones use R22.
10-09-2007, 04:27 PM #6
Thanks Sanderh.
What is STEK?
do these systems have coils against/inbetween sever blades? or more traditional 'AC' space cooling?
10-09-2007, 05:09 PM #7
STEK is something like a guilds diploma in the UK, that one has to have in Holland to work on refrigeration equipment.
The ones I work on all are AC systems, where the air is "sucked" away at or above the ceiling, is cooled in the CCU and blown under the floor and goes trough the racks.
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Close call (eye opener)
By Tycho in forum IndustrialReplies: 42Last Post: 17-03-2006, 07:33 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
