Results 1 to 1 of 1
    Jan 2007
    Poland
    49
    12
    Single compression vs two stage compression.
    answer me please advantages of using two stage compression vs single stage for supermarket LT range (to=-37/tc=40oC). I have made simple comparison between similiar compressors at nearly identic working conditions based on Bitzer software. Is this advantage a current which is about 20% less for two stage?
    COP is a bit better for single stage.
    Or maybe I omitted some others factors which are essential for such comparision.
    I know that is not recommended to use single compression when compression ratio is higher than 8 and then apply two stage one. Is this main reason?
    Awaiting your help
    BrgPawel
  1. Building a 3 stage cascade
    By NoL in forum CPU Overclockers
    Last Post: 27-03-2009, 08:42 PM
  2. Single stage refrigeration system optimizing diagram
    By autt in forum System Optimization
    Last Post: 03-12-2008, 03:13 PM
  3. Replies: 7
    Last Post: 13-12-2007, 06:31 PM
  4. Single stage Vs 2 stage comp rack
    By Kevin Yeo in forum Supermarket Refrigeration
    Last Post: 01-02-2007, 03:05 PM
  5. single stage screw compressor
    By murugan in forum Trouble Shooting
    Last Post: 18-05-2006, 01:27 PM
