Thread: On it's side?
06-09-2007, 10:57 PM #1
On it's side?
From what I can tell I'm not exactly your typical character around here. I'm actually a graphic designer who dabbles in industrial, fashion, automotive, and a varity of other design mediums on my free or fun time. (Which is in limited supply)
I'm looking to modify/hack/splice/*******ize an LG residential fridge/freezer so that it can be on it's side rather than upright.
It's a fridge freezer combination and I want to rotate it on it's side so that the fridge doors open like a draw bridge sort of thing. From what I've been told the compressor goes all wonky if it's on it's side.
I'm not exactly sure what's involved. Some of you might have to hold my hand for this one. But is there somewhere I can start?
06-09-2007, 11:20 PM #2
Re: On it's side?
Simple really, if you are VERY careful then turn the fridge freezer on its side and then rotate the compressor back to it's normal position without snapping, kinking or puncturing the pipework.
It's not a frost free is it?
Cause it wont work if it is.
and go get a cuppa
06-09-2007, 11:24 PM #3
Re: On it's side?
Well, you could get the compressor repositioned so that 'it' remains in the upright mode.
You may need to look into the construction/layout of the condenser coil - the black serpentine at the back - the hot gas inlet needs to be at the top with the condensed liquid running out at the bottom of the coil.
You could have a major problem however with the food falling off the vertical shelving insideBrian - Newton Abbot, Devon, UK
07-09-2007, 12:38 AM #4
Re: On it's side?
You've both seem to have forgotten the drain won't work. Also some defrost heaters are just below the coil, not over it, and they rely to heat rising to defrost the coil, so you won't get a proper defrost on some models of fridges.
Which won't matter because there's no where for the water to drain out of.
07-09-2007, 05:20 PM #5
Re: On it's side?
Thats why I said it wont work if its a frost free.
and go get a cuppa
08-09-2007, 09:20 PM #6
samsung side by side
By Pete the cool in forum DomesticReplies: 19Last Post: 11-04-2010, 07:00 PM -
High Side Pressure is ...
By SULTAN in forum Trouble ShootingReplies: 5Last Post: 14-08-2007, 12:53 PM -
Samsung side by side
By Pete the cool in forum Trouble ShootingReplies: 9Last Post: 12-12-2006, 06:28 PM -
Whirlpool side by side - Freezer intermittent fault
By Chouman in forum Trouble ShootingReplies: 14Last Post: 17-11-2006, 10:34 PM -
Kenmore side by side defrost problem!! Need help
By vanstelp in forum Trouble ShootingReplies: 3Last Post: 28-09-2006, 08:30 PM
