Thread: On it's side?
    froggysan's Avatar
    froggysan Guest
    On it's side?
    From what I can tell I'm not exactly your typical character around here. I'm actually a graphic designer who dabbles in industrial, fashion, automotive, and a varity of other design mediums on my free or fun time. (Which is in limited supply)
    I'm looking to modify/hack/splice/*******ize an LG residential fridge/freezer so that it can be on it's side rather than upright.
    It's a fridge freezer combination and I want to rotate it on it's side so that the fridge doors open like a draw bridge sort of thing. From what I've been told the compressor goes all wonky if it's on it's side.
    I'm not exactly sure what's involved. Some of you might have to hold my hand for this one. But is there somewhere I can start?
    Oct 2004
    Scotland
    1,454
    21
    Re: On it's side?
    Simple really, if you are VERY careful then turn the fridge freezer on its side and then rotate the compressor back to it's normal position without snapping, kinking or puncturing the pipework.
    It's not a frost free is it?
    Cause it wont work if it is.
    Chillin
    and go get a cuppa
    11,025
    Re: On it's side?
    Well, you could get the compressor repositioned so that 'it' remains in the upright mode.
    You may need to look into the construction/layout of the condenser coil - the black serpentine at the back - the hot gas inlet needs to be at the top with the condensed liquid running out at the bottom of the coil.
    You could have a major problem however with the food falling off the vertical shelving inside
    Jul 2007
    Australia
    1,845
    Re: On it's side?
    You've both seem to have forgotten the drain won't work. Also some defrost heaters are just below the coil, not over it, and they rely to heat rising to defrost the coil, so you won't get a proper defrost on some models of fridges.
    Which won't matter because there's no where for the water to drain out of.
    Oct 2004
    Scotland
    1,454
    21
    Re: On it's side?
    Thats why I said it wont work if its a frost free.
    Chillin
    and go get a cuppa
    Mar 2007
    Iraq
    57
    Re: On it's side?
    some ideas worth much
  1. samsung side by side
    By Pete the cool in forum Domestic
    Last Post: 11-04-2010, 07:00 PM
  2. High Side Pressure is ...
    By SULTAN in forum Trouble Shooting
    Last Post: 14-08-2007, 12:53 PM
  3. Samsung side by side
    By Pete the cool in forum Trouble Shooting
    Last Post: 12-12-2006, 06:28 PM
  4. Whirlpool side by side - Freezer intermittent fault
    By Chouman in forum Trouble Shooting
    Last Post: 17-11-2006, 10:34 PM
  5. Kenmore side by side defrost problem!! Need help
    By vanstelp in forum Trouble Shooting
    Last Post: 28-09-2006, 08:30 PM
