Thread: condenser cooling water flow
06-09-2007, 05:21 PM #1
I have 4 salt water cooled condensers . How would I find out the amount of water, ( gallons per minute ), That I need in each condenser. Hp 80 is the refrigerant in all 4.
The problem I have is that the old pump is not supplying enough water when it's all running and needs to be replaced
06-09-2007, 06:12 PM #2
Re: condenser cooling water flow
The manufacturer of the condenser should be able to tell you what gpm's are required.
07-09-2007, 06:07 AM #3
What is the make and model number of the condensers? Also, you say that the old pump is not supplying enough water. Was it sufficient in the past? If it is worn out perhaps all you need is for the condenser pump to be rebuilt.
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
