    Apr 2007
    United States
    Replacement Screw Compressors
    All,
    I'm looking to replace a Frascold RTSL1-70-240Y compressor used in a low temp R404a application.
    Here in the US, Frascold is not particulary common and I'd like to consider a replacement that is more commonly available and supportable.
    Additionally, my company has seen a fairly short life span on the Frascold's, likely due to poor controls and safeties. What ever my replacement compressor solution is, I also need to replace the control and safety system.
    Are there any units or suppliers that either have a particularly good, or poor reputation?
    Many thanks!
    Win Kemper
    Mar 2006
    dallas, texas
    75
    108
    Re: Replacement Screw Compressors
    If you need a semi hermetic there are several us brands available. You can probably get good oem numbers from Hartford on the verticals and i feel sure there are at least 3 or 4 others that would be pleased to get an oem account.
    Oct 2007
    malaysia
    8
    You can choose Bitzer semi hermetic screw compressor which is very realiable. The replacement model should be model HSN 7461-70 ( please contact Bitzer US to double confirm this ), but i suggest you also change the oil and also change oil separator ( original Bitzer made for screw application ), please ensure your oil cooler still working well to able to always keep oil temperature about 70oC.
  1. Replacement Compressors for Inverter A/C
    By Electrocoolman in forum Air Conditioning
    Last Post: 30-03-2007, 08:59 AM
  2. reciprocating compressors vs screw, for NH3
    By lraja in forum Industrial
    Last Post: 04-03-2007, 02:30 AM
  3. I Need some BIG USED Screw compressors
    By bruceboldy in forum Industrial
    Last Post: 16-06-2006, 12:06 AM
  4. Variable speed screw compressors
    By Friobernal in forum Industrial Compressors
    Last Post: 14-11-2004, 09:28 AM
  5. Screw compressors
    By bernard in forum Supermarket Refrigeration
    Last Post: 05-06-2004, 05:06 PM
