Thread: Replacement Screw Compressors
Threaded View
13-10-2007, 07:22 PM #3
Re: Replacement Screw Compressors
You can choose Bitzer semi hermetic screw compressor which is very realiable. The replacement model should be model HSN 7461-70 ( please contact Bitzer US to double confirm this ), but i suggest you also change the oil and also change oil separator ( original Bitzer made for screw application ), please ensure your oil cooler still working well to able to always keep oil temperature about 70oC.
Replacement Compressors for Inverter A/C
By Electrocoolman in forum Air ConditioningReplies: 2Last Post: 30-03-2007, 08:59 AM -
reciprocating compressors vs screw, for NH3
By lraja in forum IndustrialReplies: 15Last Post: 04-03-2007, 02:30 AM -
I Need some BIG USED Screw compressors
By bruceboldy in forum IndustrialReplies: 0Last Post: 16-06-2006, 12:06 AM -
Variable speed screw compressors
By Friobernal in forum Industrial CompressorsReplies: 1Last Post: 14-11-2004, 09:28 AM -
Screw compressors
By bernard in forum Supermarket RefrigerationReplies: 2Last Post: 05-06-2004, 05:06 PM
