Results 1 to 8 of 8
    India
    688
    High Humidity Chamber
    We had constructed a test chamber for CAR testing. It was earlier thought that it shall be for temp. variation right from -40 to + 40 deg c. But now the client is also increasing the humidity level upto 95%.
    Now this chamber is not gas leak proof as it is seen now. The reason is when the temp goes up the silicone sealent applied from inside gets separated & the steam is leaking out. THis is happeing mostly at the wall / ceiling joints.
    The inside surface is SS 304 & hence it is very difficult to apply a special resin / tape which are available for such applications. Any suggestion to stop this. We can consider Al Bitu tape, but will that stick on SS 304?
    11,025
    Re: High Humidity Chamber
    Could you use a 'rubber' seal secured to the base frame with a ss strip screwed over it?
    Feb 2007
    2,473
    45
    Weld the joints and put a rubber seal around the door(s)?
    India
    688
    Welding is not possible as the panel skin thickness is hardly 0.5mm. But the idea of gasket being screwed down could be workable. We shall do this & post the result on this forum
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi,smpsmp45
    Quote Originally Posted by smpsmp45 View Post
    I believe that special kind of pop rivets are better, more tight...with screw you have always a leak...
    ...maybe you can use a special aluminum self adhesive tape (50mm wide) what we use to seal cold room ceiling panel joints from top. It is very light and adhesive is very strong...I do not know the manufacturer but we use that in India.
    we also use angle SS profiles riveted to ceiling and to the wall with sealant under both ends for inside corners, of course when panels are SS type...
    Best regards, Josip
    India
    688
    Dear Josip,
    Are you talking about Al Bitu Tapes. That is a al tape with a bitumen backing. That is what is being used for ceiling joints. The problem with that is when we apply that on SS 304 surface, the sticking is not so good. & with temp variation that easily comes off.
    But that works very well with precoated sheets.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, smpsmp45
    Dear Josip,
    No, this is kind of very strong self adhesive plastic tape (very thin but strong) highly polished (Chrome finished like and that glue/adhesive is very strong...)
    Sorry, my camera is broken to make a photo and upload here....
    Best regards, Josip
    India
    688
    Dear Josip,
    This is some new information. Can you send some specification sheets or manufacturer details?
  1. Compressor loading, cooling, and range of operation.
  2. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  3. open cycle R718 A/C that also provides high purity water?
    By star882 in forum Technical Speculations
    Last Post: 27-07-2006, 04:18 AM
  4. Building a wine cabinet
  5. Humidity
    By frank in forum Air Conditioning
    Last Post: 30-12-2002, 08:06 PM
