    tzs's Avatar
    tzs Guest
    AEG frost free fridge
    I have an AEG Santo 72358KA frost free fridge, installed just under 2 years ago. I noticed a few weeks ago that there was a build up of frost inside the fridge. I called AEG for advice and they suggested I check that the drain hole was not blocked. This I did and it was clear. I changed the carbon filter, defrosted the fridge and the frost has come back. The temperature is showing a steady 5 degrees. Has anyone any idea what might be causing this and how it can be fixed without the £65 callout charge?
    Jul 2007
    united states
    43
    21
    Re: AEG frost free fridge
    Quote Originally Posted by tzs View Post
    Unfortunately the warranty is not in effect? If this is the case, I would suggest the callout charge. If you knew what a defrost timer and hi-limit were then you could probably repair it yourself. One of those is most likely your culprit.
    leo's Avatar
    leo Guest
    Hey tzs,
    Have you managed to fix this perma-frost problem? I'm very interested to hear your story. Thanks
    barkerma's Avatar
    barkerma Guest
    Hi guys,
    did either of you ever fix this problem? I have the exact same problem with my Santo 3688 fridge and the engineer is at a loss as to what is causing the frost build up.
    thanks
    Mike
    Oct 2008
    mallorca, spain,
    75
    768
    perhaps its the de-frost heater thats
    fknakered,
  1. LIEBHERR Frost Free fridge
    By Lucas in forum Domestic
    Last Post: 30-09-2008, 09:07 PM
  2. frost free
    By sashy552 in forum Domestic
    Last Post: 22-06-2007, 11:20 PM
  3. Bosch No Frost Fridge is frosting HELP
    By cooper1258 in forum Domestic
    Last Post: 22-08-2006, 11:48 PM
  4. Leaking frost free fridge-freezer
    By diment01 in forum Domestic
    Last Post: 22-06-2006, 11:49 PM
  5. Frost free fridge/freezer
    By ice-cold in forum Commercial
    Last Post: 26-05-2005, 07:55 PM
