Results 1 to 14 of 14
Thread: Belt tightening tool
03-09-2007, 04:56 PM #1
Come across a few belts recently on motors that have snapped due to being to tight. I was told today about a tool that can be bought to measure belt tightness. I was told that it had a spring in it which indicates weather its too slack or too tight, anyone heard of it and where i can get hold of one?
03-09-2007, 06:13 PM #2
Re: Belt tightening tool
I think mechanics use these a lot to tension the water pump belts on cars.
Snap-on should have one.
and go get a cuppa
03-09-2007, 07:02 PM #3
sounds good thanks, i imagine they are pricey from snap on but il have a look.
03-09-2007, 07:36 PM #4
Found a link for you...
http://www.primetools.co.uk/index.ph...tart=41&num=20
and go get a cuppa
03-09-2007, 07:56 PM #5
Great, thanks Chillin, just what im after
03-09-2007, 08:06 PM #6
The other option is the "90° twist test".
Hold the belt between your forefinger and thumb, if you can twist the belt through 90° without struggling then the tension should be about right.
There you go, no chargeLast edited by Brian_UK; 03-09-2007 at 08:08 PM. Reason: Spelling!
04-09-2007, 01:56 AM #7
I am told that there are no more "matched sets" of belts, even though you can buy a multiple pulley belt for commonly sized air handlers.
I see all these Harley Davidson motorcycles with what appears to be a damn timing belt instead of a chain. We have all these adjustable pulleys and belt sizes with angles and wedgy cuts.
Am I wrong, but isn't the duty of a Harley Davidson belt drive sufficiently adequate for most air handlers? What am I missing?
04-09-2007, 02:25 AM #8
I bought mine from the pulley and belt supplier - special order for about Oz$50. Don't really use it much now - I've got a good feel for it, but it impressed a few building managers. I needed to carry a chart of tention for the different belts.Any way have you seen the new vented pulley design? they weigh about half as much and run the belts 17degC cooler. Cheers Bro
04-09-2007, 03:13 AM #9
Originally Posted by Dan
http://www.gates.com/brochure.cfm?br...cation_id=6196
http://www.gates.com/index.cfm?location_id=534
Note: you may have to register for access to the information, but this should provide a start...
I used to use the notched belts in lieu of the standard v-belt because I thought the ran cooler due to the increased surface area and the notches providing a cooling effect when rotating.If all else fails, ask for help.
04-09-2007, 06:01 PM #10
I use either the belt twist test like Brian_uk said, or a clamp ammeter on the motor.
I tighten and test using visual/audio and amps.
If it's pulling too high amps I loosen the belt, if it's slipping and the pulleys and belts OK I tighten until FLA met.
06-09-2007, 05:21 PM #11
Great thanks guys
02-09-2008, 09:00 AM #12
Go to a Fenner belt agent and they will be able to give you a belt guide with all the relevent tables for proper belt adjustment. You will also be able to get yourself a belt tension tool, which are inexpensive.
Regards.
02-09-2008, 04:46 PM #13
02-09-2008, 09:27 PM #14
i got one of these tools from bearing services a belt and bearing supplyer
Mitsubishi Maintenance Tool
By sigorst in forum Air ConditioningReplies: 4Last Post: 23-03-2010, 09:05 PM -
Handheld air cleaner tool
By Alexbox in forum Tools and CalculatorsReplies: 4Last Post: 19-01-2007, 06:12 AM -
Mitsubishi M-Net Maintenance tool
By sigorst in forum Air ConditioningReplies: 3Last Post: 07-03-2006, 06:27 PM -
Tool cases
By bernard in forum Chit Chat & Service StoriesReplies: 6Last Post: 22-06-2005, 01:09 PM -
Looking for a Good CRM or Database Tool for marketing any help
By PAXFREON in forum Legal-Business-MarketingReplies: 2Last Post: 12-03-2004, 05:53 PM
