Thread: Frick O-ring
    Jul 2005
    France- USA
    47
    27
    Frick O-ring
    Hello,
    I have heard that Frick has different O-ring type, depending of the type of refrigerant and oil.
    O-ring for HCFC and mineral oil are different that O-rings for HFC and esther oil.
    is it true ?
    Where can I find spec for the HFC O-rings ?
    Jul 2006
    73
    865
    26
    Re: Frick O-ring
    O rings are different for different applications. Buna N and Neoprene are different options, but there are others as well.
    Durometer is another variable.
    I have found the best source is Frick itself.
    They may or may not divulge the composition of the ones they sell.
    Jul 2005
    France- USA
    47
    27
    Re: Frick O-ring
    Thanks NH3LVR...
    The problem is that when you order a gasket kit, there is only one reference....so how is it possible to get a different type of gasket ???
    I saw that on our Frick XJF 120 working with R507, the shaft seal is leaking much more early than same shaft seal mounted on XJF 120 working with R22...
    May 2003
    Canada
    31
    Re: Frick O-ring
    When you order are you using the sales order number? Frick shaft seals can be very problematic, but they warranty almost all of them as long as the rma is filled out properly.
    Jul 2006
    73
    865
    26
    Re: Frick O-ring
    Quote Originally Posted by 404cab View Post
    I believe that they supply different parts for the different sales order numbers, looking up the parts for each individual compressor.
    May 2003
    Canada
    31
    Re: Frick O-ring
    That they do NH3LVR only problem in this case is they switched refrigerants so the info related to the sales order number will still be for the old refrigerant.
    Jul 2006
    73
    865
    26
    Re: Frick O-ring
    Quote Originally Posted by Industrial tech View Post
    I failed to discern that from 404cab's post.
    Appreciate you catching it.
  1. Frick XJF/XJS 120 compressors
    By 404cab in forum Industrial Compressors
    Last Post: 15-11-2011, 02:57 PM
  2. Frick Premature Seal Failures
    By Steve Wright in forum Industrial Compressors
    Last Post: 11-06-2010, 02:34 PM
  3. Frick Micro Control Panel Problem
    By derfriguy in forum New to RE
    Last Post: 11-04-2007, 07:45 AM
  4. old frick system monitor
    By rasgrant in forum NH3
    Last Post: 17-01-2007, 06:15 PM
  5. Frick Exploded View
    By adarsh99 in forum Industrial
    Last Post: 04-02-2006, 07:16 PM
